I sat my 5D with my 24-70L mounted to it on a bench at the race track. This bench is normally a safe haven, but a friend decided to climb up onto it and inadvertently knocked my camera and lens to the ground.
The lens was wearing its lens hood, but I suppose it popped off. (I wasn't there and didn't see it happen, so I can't say for sure how it all happened, but anyway). The brunt of the impact was absorbed by my B+W filter (and this is a reason why I use filters). The impact jammed the filter onto the lens's threads; I cannot remove it. The lens's glass was not damaged that I can tell.
My local camera shop man said he's done this work before -- he carefully cuts the old filter ring off the lens. He said it's tricky work and the cost would be $90 and maybe more, depending on the level of effort.
Maybe my camera guy can do the job, but maybe I need more? Where to send it for repair? The lens, which is a brute, of course, seems to function just fine, but in reality it probably needs a check-up.
