Thread started 18 Apr 2014 (Friday) 13:34
Just Purchased Minolta Lenses
Bracetty
Joined Dec 2012
Apr 18, 2014 13:34 |  #1
Wanting to convert to EOS, I only pad 30 bucks buck I got a 50 1.7 and a 28 2.8. I see the conversion doesn't appear to be simple, but I am wondering what I would need. This appears to require addtl glass but I did see some without glass. What would the room recommend to make this work? Or should I just sell and move on?
http://dopelahomacity.​tumblr.com/ (external link)
Canon 6D & 60D Gripped, Bower 85mm 1/4, Canon 50mm f1/4, 70-200 2.8 L IS V2, Canon 135mm 2.0 L, Tamron 24-70 2.8 VS, 2X Yongnuo 580
Bracetty
Joined Dec 2012
Apr 18, 2014 13:46 |  #2
come across many threads saying its not worth the hassle but many of them were old threads. New experiences anyone?
gasrocks
Apr 18, 2014 14:30 |  #3
Sell them as is on eBay. They are not speical and very hard to adapt to your body.
Bracetty
Joined Dec 2012
Apr 18, 2014 14:56 |  #4
do you go out of your way to give the most negative perspective on each and every post?
lilkngster
Apr 18, 2014 15:10 |  #5
Converting either of those two lenses is probalby not worth it. The adapter with glass does degrade your image and glassless adapters lose long distance (infinity) focus. Still better than not being able to use your lenses at all. In the future, if you pick up a mirrorless camera, including EOS M, you can adapt your lenses without any issues.
6dII/1dIII|Bronica Sq-Ai/EOS 3/A1
KirkS518
Joined Apr 2012
Apr 18, 2014 15:50 |  #6
I'm guessing you bought those before reading my last post in your other thread.Minolta/Konica are not worth the hassle.
gasrocks was not being negative, just that, honestly, there is nothing positive to say about trying to adapt Minolta lenses to the EOS system, much like what was said about trying to convert the FD's to EOS.
If steroids are illegal for athletes, should PS be illegal for models?
Digital - 50D, 20D IR Conv, 9 Lenses from 8mm to 300mm
Analog - Mamiya RB67 Pro-SD, Canon A-1, Nikon F4S, YashicaMat 124G, Rollei 35S, QL17 GIII, Zeiss Ikon Ikoflex 1st Version, and and entire room full of lenses and other stuff
Bracetty
Joined Dec 2012
Apr 18, 2014 16:00 |  #7
KirkS518 wrote in post #16844473 (external link)
"there is nothing positive"? I don't have a 50mm, now I have a acquired one for 1/4th the price. Actual information is more beneficial than a yes or no to someone who is asking for assistance. thanks for the reply, but if you aren't going to add information that I can use please don't even bother.
PH68
Joined Jun 2013
Apr 18, 2014 16:15 |  #8
However, they do work very well with a simple adapter for the Fuji X-system or micro 4/3 cameras.
5Diii | 35/2 | 100/2.8L | 300/4L
Jerobean
Apr 18, 2014 16:17 |  #9
Bracetty wrote in post #16844504 (external link)
no, you paid 1/4 the price for a lens that doesn't work well on your system.
gasrocks knows his sh*t when it comes to old manual lenses. He isn't being negative, he's being real.
if the lens needs an optical adapter, then you have to spend significant money on one to get something that gives you okay results. cheap ones will give your garbage images.
so, for less than you'll spend getting this turd adapted over, you could have bought a 50 1.8 which has AF and probably better IQ.
6d, 24-105L, Tak SMC 50 1.4, 85 1.8, 135L
DreDaze
Gallery: 49 photos
Apr 18, 2014 17:15 |  #10
Bracetty wrote in post #16844320 (external link)
the truth hurts sometimes...without adding an emoticon it comes out blunt...say he puts a smiley face on the end of that, then you wouldn't have taken it so badly...
buy the bottom line is...it's usually better to ask before buying
Andre or Dre
gear list
Instagram (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Apr 18, 2014 17:19 |  #11
A couple links with info that might be of help;
https://photography-on-the.net/forum/showthre​ad.php?t=57023
https://photography-on-the.net/forum/showthre​ad.php?t=70506
The first, which is a very informative thread, confirms soundly what has been said already here;
"Brands that can only be used with an optical adapter -and so are not worth using in my opinion- are:
Canon FD
Minolta MD/MC
Minolta AF"
More importantly however, these threads list lenses that ARE very good choices for adapting! :)
CDS' HOT LINKS
KirkS518
Joined Apr 2012
Apr 18, 2014 19:12 |  #12
Yes, I'll say it again. THERE IS NOTHING POSITIVE ABOUT BUYING SOMETHING THAT DOESN'T WORK PROPERLY ON YOUR SYSTEM - AT ANY PRICE.
Had you read your other thread, you would have noticed that the list of lenses to keep an eye out for was given to you, and on that list, Minolta is in the 'not compatible' section, and had been specifically pointed out (by me I might add) that Minolta is not one you should look for. For $10 you could have gotten a Fuji 2.2 50mm, that would have adapter over with a $3 ebay adapter, correctly. Now which is more positive - getting a non-compatible lens and having to buy an adapter for about a total of $60, or getting a 50mm lens with adapter for about $12?
msowsun
"approx 8mm"
Gallery: 18 photos
Apr 18, 2014 20:27 |  #13
Here is a POSITIVE suggestion for you. ;)
New THIN glassless Minolta to Canon adapter for about $20: http://www.ebay.com …ens+to+Canon+EO​S&_sacat=0 (external link)
I see that there are now "Thin" Minolta to Canon adapters available. Canon and Minolta are only .5mm different in flange-to-focal-plane distances. Hopefully this thin adapter should allow you to focus at normal distances of 5-10 feet. Before you buy it just take you Minolta lens at infinity focus and hold it up against the body lens and look through the viewfinder. Some people call this "free-lensing". I have done this with Canon FD lenses and was able to focus about 3-4 feet away with a 50mm lens. (telephoto lenses can focus farther)
If you can focus about 10-20 feet with the lens up against the body, the new "Thin" adapter might work for you.
sandpiper
Apr 18, 2014 20:31 |  #14
Bracetty wrote in post #16844150 (external link)
So, you had already read many threads saying it's not worth the hassle, but asked for opinions anyway. Then when people reply saying exactly what you already know from the other threads, that the Minolta lenses are not worth adapting to fit an EOS body, you throw a hissy fit and accuse everyone of being negative and not giving you any good information.
What reply would you like to receive? Let me know and I will give it to you, a wonderful glowing report on using Minolta lenses on an EOS. Of course, that will just have you go out and buy an adapter and then realise that you have wasted your money because the results are so bad.
These people are simply being honest with you, and answering your question. You started off by saying that you have seen a lot of people saying they are not worth the hassle, did you expect to get a different answer in this thread?
Gasrocks gave you some good advice, your best option is to sell them on ebay and hopefully get your money back. Then look for some cheap lenses that actually work on your camera.
EverydayGetaway
Gallery: 11 photos
Joined Oct 2012
Apr 18, 2014 20:57 |  #15
Sorry, but he's right... those lenses are mediocre at best and they're a huge hassle to adapt. If it was a 50/1.2 then I might say otherwise.
Here's a few quick examples which would be better for your camera
http://www.ebay.com …enses&hash=item​4ad29aa706 (external link)
http://www.ebay.com …enses&hash=item​35d0c39dc8 (external link)
Heck, I've found 2 50mm's for basically free at thrift stores that were attached to old SLR's (Yashica DS-M 50/1.7 and Vivitar 50/1.9) and both are very decent lenses. You just have to know what mounts work, Minolta isn't one of them unless you find a rare lens for good money (like a f1.2 prime), neither is FD or Fuji FM/DM or Konica/Hexanon.
Fuji X-T3 // Fuji X-Pro2 (Full Spectrum) // Fuji X-H1 // Fuji X-T1
flickr (external link) // Instagram (external link)www.LucasGPhoto.com (external link)
2,910 views & 0 likes for this thread, 13 members have posted to it and it is followed by 4 members.
1050 guests, 111 members online
