So I bought a fake BG-E11. It is - all things considered - a very, very accurate copy of the real thing. I got suspicious, because the grip looked brand new although it was priced and advertised as used. It is a shame that the maker didn't simply put his own brand logo on the thing, because it is actually nicer than the third-party Pixel/Vertax grip I own too.
If you want to check whether you too got a fake I suggest looking for these subtle differences:
- metal insets in the interior are missing (top side) or looking different (matt in the real deal, shinny in the copy)
- no rubber seals on the battery cartridges
- weight (genuine 372g, copy 322g both with installed battery cartridges but without batteries)
- the exact structure of the fake leather coating
- the additional pouch (this is the most obvious but might be missing if you are buying something that's supposedly used)
- stiffness - I was able to squeeze the copy when applying pressure without installed battery cartridges for approx. 0.5mm - 1mm, the genuine grip is solid as a metal slab
- the serial number on the fake was fading after using the grip for a day (I blurred the serial number on the genuine grip)
Given the fact that this thing is such an excellent copy I highly suggest you do not purchase a grip from anything else than a top reseller (preferably certified by Canon) - at least if you expect to get the real thing.
