Thread started 24 Apr 2014 (Thursday) 17:07
I need a very specific piece, but I don't know if it exists
steelbluesleepr
Apr 24, 2014 17:07 |  #1
I'm trying to make a rig and need to connect my magic-arm to my extension arm. they both have male 5/8" spud ends (like the top of a light stand without the 1/4-20 threaded portion. I'm trying to find a female-female connector to attach them end-to-end with a thumbscrew to secure both ends. it should be a simple collar with two screws coming out the side, but I cannot find anything like this.
Does anyone know where to find this piece?
-Jayson- my flickr (external link)
In the bag: 5D mark II+Vello grio/10d+grip/Canon 17-40L/Canon 28-135/Canon 50 1.8/Canon 35-80 Macro Conversion/Vivitar 135 2.8 M42/Vivitar 28 2.5 M42/Yongnuo YN460II x3/Yongnuo RF-602 x3
peeaanuut
Gallery: 33 photos
Apr 24, 2014 17:12 |  #2
its the thumbscrew thats throwing it off. There are plenty of FtoF couplers.
You can try something like this
http://www.amazon.com …ng-Coupling/dp/B0060LVURU (external link)
Stuff
http://joetakesphotos.​com/ (external link) : | : https://www.facebook.c​om/JKlingPhotos (external link) : | : https://twitter.com/jk​lingphotos (external link)
airbutchie - Joe was definitely right about adding contrast...
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Apr 24, 2014 17:12 |  #3
Would something like this work?
http://www.amazon.com …F8&qid=13983774​41&sr=1-69 (external link)
What exactly are you trying to do?
500px (external link)
1x (external link)
instagram (external link)
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Apr 24, 2014 17:16 |  #4
peeaanuut wrote in post #16858950 (external link)
Yeah, but the thumbscrew makes sure they don't slide apart.
1x (external link)
steelbluesleepr
Apr 24, 2014 17:18 as a reply to  @ Scatterbrained's post |  #5
both of those are very expensive options (the latter I'm not sure if it's sturdy enough). The thumbscrews are mainly there to hit the flat-spots on the studs to keep it from torquing itself out of framing.
I'm trying to make a bike rig that will be:
Motorcycle => super clamp => extension pole (two male ends) => female-female adapter => magic arm => camera
I was hoping I could find an aluminum or steel collar made specifically for photo/video work for like $5-10, otherwise I'll just buy a male-female light stand extension pole for $35.
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Apr 24, 2014 17:24 |  #6
Are you just trying to get the camera high above the bike?
If you're going for a "rig" shot there are other ways to do it. What kind of shot are you trying to achieve?
1x (external link)
steelbluesleepr
Apr 25, 2014 13:47 |  #7
This is what I'm trying to somewhat emulate:
se7enxn9ne wrote in post #16804113 (external link)
Here's the BTS image he sent me:
IMAGE: https://farm3.staticflickr.com/2829/13575307583_f01838c384_b.jpg
Basically, I have everything I need to do this except for a way to connect my extension boom to my magic arm. He's using a female=>male extension whereas I have a male=>male extension.
tandemhearts
Joined Mar 2014
Apr 25, 2014 13:56 |  #8
How about this
http://www.amazon.com …r=8-5&keywords=drum+clamp (external link)
IMAGE: http://ecx.images-amazon.com/images/I/41vuko5GqTL.jpg
In use
http://www.youtube.com …GCPfeD3bgs3BciX​gTdQT_QFk7 (external link)
SkipD
Joined Dec 2002
Apr 25, 2014 14:13 |  #9
steelbluesleepr wrote in post #16858942 (external link)
Any machine shop should be able to create precisely what you want out of a 1" diameter steel round bar. You'd have them bore a 5/8" ID hole (plus a little more for clearance with your spuds) in each end, then drill and tap holes for the locking bolts at each end.
I'd suggest forgetting the thumbscrews and use bolts that are tightened with a wrench.
Skip Douglas
steelbluesleepr
Apr 25, 2014 14:21 |  #10
SkipD wrote in post #16860927 (external link)
I know it's easily made, I was just seeing if anyone knew of a reasonably priced piece that was already a commercial product.
Csae
Apr 25, 2014 15:38 |  #11
I'm confused, why does your magic arm have a male connection ? Normally the extension boom would end in male, Or people would use a clamp on a thicker pipe. Keep in mind that you want to keep the connection points as simple as possible to avoid risk of failure or wobble.
http://www.bhphotovide​o.com …ale_Converter_S​ocket.html (external link)
This is a Female / Female connector that might work for you.
Feel free to call me Case.
CasePhoto.ca (external link) - FanPage (external link)
-Montreal based Photography.
steelbluesleepr
Apr 25, 2014 16:14 |  #12
Csae wrote in post #16861144 (external link)
thank you! that's exactly what I need.
btw, all magic arms that I've ever seen have two male ends. the extension rod I'm using has two male ends because it's part of a low-profile light stand (like this: http://www.ebay.com/it​m/like/290883632477?lp​id=82 (external link)) and its legs attach to the pole via a female connector.
Csae
Apr 26, 2014 05:43 |  #13
Oh, you're right i must of been thinking of something else.
Glad we found the part you needed : )
steelbluesleepr
Apr 26, 2014 12:53 as a reply to  @ Csae's post |  #14
Even better, I found a female-male stand extension that I got in a group of other grip gear off of craigslist!
2,576 views & 0 likes for this thread, 6 members have posted to it.
1038 guests, 115 members online
