I have a rebel T2i and it replaced my previous tebel Xt/ I want to upgrade to a better camera but want to be able to keep using my lenses. So, i will need a compatible camera. Any suggestions or advice what could be my next EOS camera?
drogi1 Mostly Lurking 18 posts Joined May 2009 More info | Apr 25, 2014 07:41 | #1 I have a rebel T2i and it replaced my previous tebel Xt/ I want to upgrade to a better camera but want to be able to keep using my lenses. So, i will need a compatible camera. Any suggestions or advice what could be my next EOS camera?
CollegeKid Senior Member 475 posts Joined Mar 2014 More info | Apr 25, 2014 08:18 | #2 Permanent banIt would help to know which lenses you have. Any lens designated "EFS" will work on any Camera that has a letter name like XT, XS, XTi, T3i, etc. They will also work on XXD and XXXD cameras where XX(X) is numbers, such as 450D, 60D, 650D. They will also work on, specifically, the 7D.
Echo63 Goldmember 2,868 posts Likes: 169 Joined Aug 2006 Location: Perth - Western Australia - Earth More info | Apr 25, 2014 08:33 | #3 what is your current body not doing for you ? My Best Imageswww.echo63.deviantart.com
Thank you very much CollegKid and Echo63.
Apr 25, 2014 08:57 | #5 drogi1 wrote in post #16860201 Thank you very much CollegKid and Echo63. I have the canon 50mm 1.4f and the 100mm macro by canon too. Not sure if it's EF or EFS. will check when I get home. Not happy with the T2i. Too slow and results are not great to my taste. And, as Echo63 said: I just want a new gear.. I thing 2k is OK for me to budget at this time Thanks again "Too slow" may be the issue with lenses, not camera. I had no problem practically instantly focusing on running kids in near complete darkness using T3i and a lens with HSM motor. Before investing in 7D make sure you won't have the same (real or perceived) problems using the same lenses. Ex-Canon shooter. Now Sony Nex.
CollegeKid Senior Member 475 posts Joined Mar 2014 More info | Apr 25, 2014 09:39 | #6 Permanent bandrogi1 wrote in post #16860201 Thank you very much CollegKid and Echo63. I have the canon 50mm 1.4f and the 100mm macro by canon too. Not sure if it's EF or EFS. will check when I get home. Not happy with the T2i. Too slow and results are not great to my taste. And, as Echo63 said: I just want a new gear.. I thing 2k is OK for me to budget at this time Thanks again For the most part, a new camera will not fix that. Both your lenses will work on any camera Canon currently sells.
thanks much
CollegeKid Senior Member 475 posts Joined Mar 2014 More info | Apr 25, 2014 11:17 | #8 Permanent banThe 7D is a great camera. It has a very sophisticated, highly configurable auto-focus system. If you need that, great. If not, the 60D is available for about 1/2 the cost of a 7D. Budget matters.
TJays Goldmember 1,400 posts Likes: 289 Joined Mar 2013 Location: Los Angeles USA More info | Apr 25, 2014 11:45 | #9 Think about better glass, maybe a 24-105 f4 L series. Camera wise, knowing what style of photography you do will better determine which camera suits your needs. Regards
kfreels Goldmember 4,297 posts Likes: 11 Joined Aug 2010 Location: Princeton, IN More info | Apr 25, 2014 13:07 | #10 I'd like more detail about how your T2i is holding you back. You say "results are not great to my taste" but I'm not sure what that means. If you are looking for a drastic improvement in IQ, you're likely to be disappointed. All of the current bodies are very close in IQ with the only real difference being a slight improvement in noise as you go to higher ISOs on the full frame cameras. (And a little more background blur when you frame your subject at the same size in the image at the same aperture). There is also a slight perspective shift that goes along with this if you step closer with a full frame camera to achieve the same subject framing. I am serious....and don't call me Shirley.
thank you all
Apr 25, 2014 14:10 | #12 FWIW, I would keep the T2i after the upgrade. If you currently have a budget of $2k, then it's worth more in your bag as a backup than the $225 you'll get for it on the used market. 1D MkIV | 1D MkIII | 550D w/grip & ML| EF 70-200mm f2.8L| EF 24-105mm f4L IS | Canon EF 100-400mm f/4.5-5.6L IS | Samyang 14mm f/2.8 IF ED UMC | 430EXii | EF 50mm f1.8
timbop Goldmember More info | Apr 25, 2014 16:51 | #13 Your current results are based on a whole system, not one component. Improving the wrong thing won't appreciably "fix" the results. The lenses you have are pretty good, although the 50 does have a slower focusing motor. The 100 macro (if it's the USM version) should be pretty quick, but there are other faster focusing lenses available. The more pro level cameras have faster AF processors and more "tweaked" algorithms for sports. If your problem is not AF speed but accuracy, then indeed a camera like the 7d will improve your keeper rate. If your problem is poor performance indoors when it's dark, then a camera like the 6d that has really good lowlight performance might do better for you (or you could add an external flash to solve the issue). Current: 5DM3, 6D, 8mm fish, 24-105/4IS, 35/2IS, 70-200/2.8IS, 85/1.8, 100-400/IS v1, lensbaby composer with edge 80, 580's and AB800's
TeamSpeed 01010100 01010011 More info | Apr 25, 2014 17:37 | #14 CollegeKid wrote in post #16860129 It would help to know which lenses you have. Any lens designated "EFS" will work on any Camera that has a letter name like XT, XS, XTi, T3i, etc. They will also work on XXD and XXXD cameras where XX(X) is numbers, such as 450D, 60D, 650D. They will also work on, specifically, the 7D. Some clarification Past Equipment | My Personal Gallery
Apr 25, 2014 17:44 | #15 [QUOTE=drogi1;16860080]I have a rebel T2i and it replaced my previous tebel Xt/ I want to upgrade to a better camera but want to be able to keep using my lenses. So, i will need a compatible camera. Any suggestions or advice what could be my next EOS camera?[/QUOTE] ---------------Camera, Lens, Flash stuff.. but still wanting more
| Latest registered member is Thunderstream 2126 guests, 96 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
