I'm cautious to try this before hearing any responses for I'm not sure if any gear could get shorted out. Having a 5d3 with a a Yongnuo RF- 603 mounted firing two remote Yongnuo 560 flashes with RF-603's attached. On top of the RF-603 that is attached to the camera I would mount a ST-E3-RT to trigger two 600 EX-RT's in ETTL. Is it possible for this to work and if so can I still use the ST-E3-RT to adjust the 600's and would I still be able to adjust the 600's from the camera's menu. The purpose is to try to use the 560's in manual mode to light a background while the 600's would be used as key and fill lights.
