So which do you use - Manual Select Spot AF or 1 PT AF, Expand Area, Expand Area Surround, Manual Select Zone AF or Auto selection?
Apr 27, 2014 15:41 | #1 So which do you use - Manual Select Spot AF or 1 PT AF, Expand Area, Expand Area Surround, Manual Select Zone AF or Auto selection? Michelle Brooks Photography
nicksan Man I Like to Fart 24,738 posts Likes: 53 Joined Oct 2006 Location: NYC More info | Apr 27, 2014 21:05 | #2 Michelle Brooks Photography wrote in post #16865291 So which do you use - Manual Select Spot AF or 1 PT AF, Expand Area, Expand Area Surround, Manual Select Zone AF or Auto selection? The AF system in the 1DX is almost the same as the one in the 5DIII. The 1DX uses color information and is probably a little bit faster in acquisition.
Apr 28, 2014 06:28 | #3 Cool, thanks, Nick! nicksan wrote in post #16865930 The AF system in the 1DX is almost the same as the one in the 5DIII. The 1DX uses color information and is probably a little bit faster in acquisition. The modes are the same as well. I use either 1 pt AF or expanded area (assist points). I never use the zone AF or auto selection and rarely use spot AF. I don't find these modes too useful at weddings since tracking subjects isn't really a difficult task at weddings. The more important aspect of the AF system is that the outer points are cross type points, which is TONS better than say the 5D2. Michelle Brooks Photography
MFG Senior Member 537 posts Likes: 7 Joined Sep 2008 Location: South Australia More info | May 01, 2014 06:39 | #4 agreed with Nick. AIPP Accredited (Australia), WPJA
May 01, 2014 16:02 | #5 So waht do you guys use in the Selectable AF Point - 61 points, Only Cross Type, 15 or 9 points? Michelle Brooks Photography
umphotography grabbing their Johnson More info | I use all 61 in mine. I shoot shallow and want to compose in camera and get that focal point where i need it. The extra spots helps me a lot. Mike
nicksan Man I Like to Fart 24,738 posts Likes: 53 Joined Oct 2006 Location: NYC More info | May 01, 2014 19:20 | #7 Michelle Brooks Photography wrote in post #16875509 So waht do you guys use in the Selectable AF Point - 61 points, Only Cross Type, 15 or 9 points? Only cross type.
May 01, 2014 20:46 | #8 Ok, thanks! Michelle Brooks Photography
May 04, 2014 12:21 | #9 I use the all cross type when I'm in dim light, but all AF points when there is good light or I'm using flash.
May 04, 2014 13:46 | #10 frugivore wrote in post #16881299 I use the all cross type when I'm in dim light, but all AF points when there is good light or I'm using flash. As for AF mode, i've always used single point, but experimenting with the others right now. If you don't mind, what's the reasons for your choices for dim or good light/flash? Michelle Brooks Photography
May 04, 2014 13:58 | #11 Michelle Brooks Photography wrote in post #16881467 If you don't mind, what's the reasons for your choices for dim or good light/flash? In good light, even the non-cross type AF points are good at latching onto something in the scene, whereas they will have trouble doing this in dim light. The cross-type AF points have a higher chance of finding some contrast to latch onto, even in lower light. My flash puts out the AF assist beam, so AF will work with any point in any light level.
May 04, 2014 14:07 | #12 frugivore wrote in post #16881487 In good light, even the non-cross type AF points are good at latching onto something in the scene, whereas they will have trouble doing this in dim light. The cross-type AF points have a higher chance of finding some contrast to latch onto, even in lower light. My flash puts out the AF assist beam, so AF will work with any point in any light level. I haven't really tested this theory in real life. In fact, I was shooting the reception last night at a wedding without flash and I think I had left all 61 AF points on. Using the 24mm and 40mm lenses I have, using the outer non-cross type point, I was still getting some decent AF. But I'm guessing that I would've gotten better AF performance with only X-type points. And even better had I had my flash on. SOunds logical! Thank you for taking the time to explain Michelle Brooks Photography
May 04, 2014 14:08 | #13 Here'a a related question- Do you use One Shot, AI Servo?? Michelle Brooks Photography
nicksan Man I Like to Fart 24,738 posts Likes: 53 Joined Oct 2006 Location: NYC More info | May 04, 2014 16:55 | #14 The ability to focus seems to be more related to having enough contrast than light levels. I can be outside in good light but shooting against low contrast targets and the non crosstype AF points would struggle.
umphotography grabbing their Johnson More info | Servo dies not miss on either body. It's the best canon has ever had. Don't be afraid of it. I use it for just about anything that's gonna move Mike
| Latest registered member is semonsters 1596 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
