uOpt wrote in post #16865661
I am ready to get a longer/wider lens for my birdwatching than 400mm f/5.6.
Now, since I do general photography, too, it would be really nice if I could use a e.g. 300mm f/2.8 with extenders to get to 420 and 600mm. I own the Mk III versions of both the 1.4 and the 2.0x. I know that I like the picture quality well enough on my 200 f/2.8 prime and the 70-200 iS2.
However... I don't like what the extenders do to the autofocus speed. The 2.0x extender in particular is terrible in that it often lets the lens search in the wrong direction first. I originally attributed this to being at f/5.6 max but I have been told it would be a lot better with a native 400mm f/5.6.
What would the situation be like with the 300 f/2.8? Anybody using that for birds?
Due to the way my gear is packed and transported I don't have a problem with the new toy being as heavy as it wants to but it would be nice if the thing wasn't too long, after removing whatever you can remove. I suppose that is precisely why Canon made the 400mm DO, is it? Would a 400mm DO + 1.4x be substantially better with AF than the 300 f/2.8 + 2.0x?
You don't say what camera you have, that can make all of the difference in the world.
The Canon 5DIII and the 1D series (all) are the only ones that can really make the extenders work like they were designed to. Not that the extenders don't slow the focus, it does, but on my 1DmkIV and my Canon 400mm 2.8 IS lens, I leave on my Canon 1.4mkIII extender. It's not bad at all, and, I can more times than not, pixel peep if I want, it's that good. (I almost always use all of my shots viewing at 100%, cropped maybe some, but not reduced in size) I have had really good results using my Canon 2.0mkIII extender too, but there's no way that I would leave that on all of the time. I usually reserve that to a documentary shot, but I'm usually surprised at the detail I get when I do use it. There is no way that I would use my 2.0 for BiF though, but, I always use my 1.4 for that.
Also, I have never used a Canon 1.4 or 2.0 mkII version of the extenders, I had the Kenko 1.4 and 2.0 before. I was happy enough, but there is a slight edge over the two brands, in my belief. I did try to use a Kenko 1.4 and 2.0 on my older Canon Xsi and my T2i, I never tried again, it sucked so bad that I put them up until I finally saved and got my 1DmkIV and 400mm 2.8...
If you have ANY other camera other than the above, I would sure borrow or rent an extender before you buy. I can't really remember anyone on this forum that was happy using them on other cameras. If you use them on a lot of cameras for a static shot, then, and only then will you probably be satisfied. That's the way I see it anyway, this has been a thing here for a lot time, and it will always be a "thing", because nobody wants to spend a LOT on a big giant lens that is capable.
Randy
