Thread started 29 Apr 2014 (Tuesday) 22:47
Lagoon and Trifid
calypsob
Joined Jan 2012
Apr 29, 2014 22:47 |  #1
I was glad to get some clear skies recently. I got about 1.45 hrs on the lagoon and the trifid with my 80mm and a .8x reducer/flattener, so 440mm F5.6. I was pretty pleased with the data, although after stacking I realized that hotpixel cleanup had hollowed out my stars. After I adjusted the settings it would no longer properly stack so I had to live with it. Oh well. It is what it is.
iso 1600 21x300 second exposures
T2i full spectrum
Barska Magnus 80mm apo with W.O. .8x apo reducer, 440mm F5.6
IMAGE: https://farm8.staticflickr.com/7308/13883337309_be537e6b22_b.jpg
IMAGE LINK: https://www.flickr.com …70374000@N08/13​883337309/  (external link)
Lagoon and the Trifid (external link) by LMNO Sunset Deluxe (external link), on Flickr
Wes
Gear: Many gears Yes.
calypsob
Joined Jan 2012
Apr 30, 2014 00:19 |  #2
Felt like I over sharpened a bit, here is a redo
IMAGE: https://farm8.staticflickr.com/7375/13884799837_f8215ed804_b.jpg
IMAGE LINK: https://www.flickr.com …70374000@N08/13​884799837/  (external link)
M20 and M8 (external link) by LMNO Sunset Deluxe (external link), on Flickr
Wes
Toxic ­ Coolaid
Apr 30, 2014 09:43 |  #3
Great target and image. I have so much LP here I have a very small window to shoot them. I really like the FOV. I kind of like the 1st one better, maybe somewhere in the middle of the two. I know that all the stars in that area make it tough to process. Nice work!
DanThoman
Apr 30, 2014 14:36 |  #4
Beautiful shots.
Dan
my gear
jimz66
Apr 30, 2014 19:36 |  #5
Wes did I read you right you stacked 21 300 second exposures? Can you elaborate on how you did this?
Canon T3 base kit with 18-55 MM Kit lens plus EOS 75 to 300 Lens
calypsob
Joined Jan 2012
Apr 30, 2014 20:35 |  #6
Toxic Coolaid wrote in post #16872257 (external link)
Moe, I agree looks a little soft now LOL! I think I'm going to try stacking them and layer mask/paint back some of the sharpness from the first image. If you ever feel like driving to Alabama we have an awesome spot to go shoot at now.
Wes
calypsob
Joined Jan 2012
Apr 30, 2014 20:40 |  #7
DanThoman wrote in post #16872934 (external link)
Beautiful shots.
Thank you Dan, lots of work went into this, I really appreciate it.
jimz66 wrote in post #16873632 (external link)
Hey Jim, yes you read correctly. I used a german equatorial mount, ioptron zeq25 with an autoguiding camera to allow me to track the main telescope, the Barska Magnus 80mm, on this object for 1 hour and 45 minutes, or 21 x 300 second shots. I use a software capture program called BackYard EOS, which is basically the astronomy version of EOS utility to automate the exposures with the T2i. Then I used a program called deep sky stacker to stack the images and then I edited the output file in photoshop. Here is a link to deep sky stacker, it will make more sense out of the stacking process than I can explain properly http://deepskystacker.​free.fr/english/techni​cal.htm (external link)
Wes
Toxic ­ Coolaid
May 01, 2014 16:15 |  #8
calypsob wrote in post #16873755 (external link)
I may be heading down that way, but to go to a track day at Barber. Get out and ring the guts out of the R6 in a legal way for a change :) It's nice to not have to dodge gravel, rocks, trees, semi-trucks, bears, deer....and oh yeah cops.
NovaTJ
May 10, 2014 07:41 as a reply to  @ Toxic Coolaid's post |  #9
Very nice work! I tend to like the first one better, but maybe somewhere in-between the two like you said. Great color and it looks like you spent more time processing than actual capture. Love the wide field of view!
Mo and I have Red zones to deal with and as of late, no clear skies to shoot. I look forward to seeing more of your work.
Greg
Astro-Tech 8" f/4 imaging Newtonian,Baader MPCC,Orion ED 80 APO F7.5,Skywatcher EQ-6 Pro,ASGT, Modified Canon 50D, Meade DSI Guide Camera, 8" SCT dovetail mounted relic, Criterion Dynascope RV-6, modified 300D, custom astro shed,and still just getting started!
calypsob
Joined Jan 2012
May 24, 2014 01:37 |  #10
NovaTJ wrote in post #16894750 (external link)
Greg
Thanks Greg, you are correct, after working out the gremlins in the field and actually capturing the image, the hard part is processing the image. I still may redo this one but I was pretty happy with this capture. I did realize later on that I had the hot pixel reduction set too high in DSS, so the cores of my stars got hollowed out! So annoying. Oh well, I plan to add some Ha and oiii to this one also so we'll see how it goes.
Wes
Nighthound
Gallery: 224 photos
Best ofs: 24
May 24, 2014 10:14 |  #11
Outstanding work Wes. The second one is on the money.
Steve
2,502 views & 0 likes for this thread, 6 members have posted to it.
Lagoon and Trifid
1609 guests, 140 members online
