Thread started 30 Apr 2014 (Wednesday) 23:46
Is it possible to adapt Fujinon XF lenses to Canon?
Lyle ­ Krannichfeld
Apr 30, 2014 23:46 |  #1
Hi there,
The new 16mm 1.4 Fujinon XF that was just announced is looking to be a pretty spectacular star lens thus far, assuming the coma and such is under control.
My question is this...is it possible to adapt this lens for use on our Canon systems? I'm not up to speed on the adapter world, beyond using the M42 lenses.
Thanks in advance!
Lyle
Fine Art Landscape/Wildlife Photographer on Maui: INSTAGRAM (external link) FACEBOOK (external link)
Tonga tours to swim with the Humpbacks: AUMAKUA TOURS (external link)
Sony A7R IV, A7RIII, 12-24G, 16-35GM, 50 1.4ZA, 85 1.4GM, Voigt 65, Laowa 100 2:1 macro
DJI Inspire 2 with X7 and 16, 24, 35, 50
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Apr 30, 2014 23:51 |  #2
The lens is designed to cover a m4/3rd sensor with no mirror (meaning very short registry distance) so I'm gonna say no on this one. The registry distance alone between the m4/3 format and the Canon EF is just too much, then add in the smaller image circle. . . . . .
edit: forgot it's APS-C, still I think the vast difference in registry distance would kill that idea.
500px (external link)
1x (external link)
instagram (external link)
EverydayGetaway
Gallery: 11 photos
Joined Oct 2012
May 01, 2014 12:20 |  #3
Not possible. You could put it on an EOS M if they made an adapter (which they don't that I'm aware of), but other than that it wouldn't work.
Assuming you'd want to put this on your 7D (it for sure wouldn't fit your 6D even if it were a DSLR lens), have you looked at the Sigma 18-35/1.8? Nearly as fast and more versatile.
Fuji X-T3 // Fuji X-Pro2 (Full Spectrum) // Fuji X-H1 // Fuji X-T1
flickr (external link) // Instagram (external link)www.LucasGPhoto.com (external link)
Lyle ­ Krannichfeld
May 01, 2014 14:30 |  #4
It would be for my 6D. That Sigma is a nice lens on the 7d, agreed.
BrickR
Joined Mar 2011
May 01, 2014 18:39 |  #5
Fuji use a mirrorless 1.5x crop factor APC-S sensor. The back of the lens needs to be closer to the sensor than the Canon register distance so it wouldn't work. Pretty much why you can't use Canon lenses on a Nikon but you can use Nikon lenses on a Canon.
Yes, the Sigma 18-35 will work on Canon FF. Will vignette wide open but actually clears up after stopping down. You can find examples on Youtube.
My junk
The grass isn't greener on the other side, it's green where you water it.
DTvn93
Joined Jan 2017
Jan 15, 2017 15:43 |  #6
And what about Fujinon 35 mm 1.4 lens on Canon?
dasmith232
Gallery: 40 photos
Joined Nov 2012
Jan 15, 2017 15:57 |  #7
The "flange distance" for Canon EF (or EF-S) is 44mm. This means that the back of the lens needs to be 44mm from the sensor.
When mounting a lens with a *longer* flange distance to a camera, you need to add some amount of (empty) space. If mounting a lens with a *shorter* distance, you need to do with with some kind of corrective optics.
I can mount my Canon lenses to a Sony E-mount body because the Sony has an 18mm distance. So my adapter is 26mm thick to fill in the difference.
The Fuji X mount distance is 17.7mm. So you need to *subtract* 26.3mm from the setup if you want to mount your Fuji lens to a Canon. I don't know of any adapters that do that.
Dave
Mostly using Canon bodies with lots of different lenses and flash.
DTvn93
Joined Jan 2017
Post edited over 6 years ago by DTvn93.
Jan 15, 2017 18:00 as a reply to  @ dasmith232's post |  #8
Thank for your answer. I'm have do research on the internet, but I cant find any adapter that use for XF on EOS..
maverick75
Joined May 2012
Jan 15, 2017 19:27 |  #9
The reason why mirrorless lenses can be made so fast, sharp and small is because they dont have a mirror in the way. Since your 6D has a mirror it it will not adapt.
EverydayGetaway
Gallery: 11 photos
Joined Oct 2012
Post edited over 6 years ago by EverydayGetaway.
Jan 15, 2017 22:55 |  #10
DTvn93 wrote in post #18245465 (external link)
That's because one doesn't exist, it's not possible.
dasmith232
Gallery: 40 photos
Joined Nov 2012
Jan 16, 2017 07:45 |  #11
EverydayGetaway wrote in post #18245706 (external link)
Agreed, and probably not in a way that would yield a high quality image. Technically, it *could* be possible with some more lens elements inside the adapter. But the optics would not be in the best location on the light path (constrained to being inside the adapter).
Therefore if such a device did exist, the quality wouldn't be great and there wouldn't be a market demand.
I only mention this because there are other cases of wanting to adapt shorter flange lenses and adapters have been created in those cases. (Again, compromised image quality.)
Dave
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Post edited over 6 years ago by Tom Reichner. (3 edits in all)
Jan 17, 2017 13:27 |  #12
Yeah, old thread, OP has moved on, etc. So what! I still want to make a point.
Lyle Krannichfeld wrote in post #16875336 (external link)
But that doesn't make any sense........it'd be like putting an EF-S lens on a full frame body.
Even if the lens could mount to the camera and not have any mirror issues, you are still left with a tiny little image circle that doesn't cover the full frame sensor. You would get photos that look like this:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2017/01/3/LQ_835341.jpg
Image hosted by forum (835341) © Tom Reichner [SHARE LINK]
I just don't understand why you would want such a thing. What good is a wide angle if so much of the field of view is all blacked out?
dasmith232
Gallery: 40 photos
Joined Nov 2012
Jan 17, 2017 20:45 as a reply to  @ Tom Reichner's post |  #13
They *do* make adapters to put shorter-flange lenses on a body. I could for example get one that would allow me to mount my old Minolta MD lenses to my Canon body. I won't, but I could. The corrective element will expand the image circle to fill the frame. But the optical quality will suffer. Plus, not all combinations are even made. I don't see anything for Fuji to Canon.
Dave
EverydayGetaway
Gallery: 11 photos
Joined Oct 2012
Jan 17, 2017 22:38 |  #14
dasmith232 wrote in post #18247806 (external link)
The difference between MD and EF mount isn't very large to begin with, the difference in flange distance between a mirrorless or rangefinder lens compared to any SLR lens is huge by comparison, any modifying lens would have a serious impact on image quality.
13,185 views & 4 likes for this thread, 8 members have posted to it and it is followed by 4 members.
1479 guests, 137 members online
