Thread started 01 May 2014 (Thursday) 02:08
Going to africa.
Africanphoto
Joined Sep 2012
May 01, 2014 02:08 |  #1
Hey guys,
I'm going to South Africa for 5 weeks in December and at this stage I am spending 10 days in the kruger national park. I am contemplating whether or not I should save up for a second body and whether it is even necessary. I already have a canon 7D and am possibly thinking of either adding another 7D or saving up for a 6D. I'd rather save more money and buy a better camera rather then buy a 60D (or similar) and have to upgrade in a few months/years.
Canon 7D, Canon 100mm L F2.8, Sigma 120-300mm F2.8 OS, Sigma 50mm F1.4, Canon 430 ex II, Sigma 2x teleconverter, Kenko extension tubes, Vello flash cord And a few bits and peices and a Yashica 635!!!
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
May 01, 2014 02:18 |  #2
Heya,
A backup camera is a good idea. Personally, I just use old unwanted crops as backups. The 7D can take the environment fine. The only thing that could happen really would be the bolt of lighting random chance of it just failing (very much not likely), or serious physical damage (more likely). You could spend $550 for a backup 60D or 5D Classic. Or you could spend $350 on a SL1. Or you could spend $180 on an XSi. Personally I don't like investing heavy into "backup" gear. And having two 7D's would be optimal, but if you're not doing this for money, and this is just for pleasure, I don't see the inherent necessity of having another one, and would rather opt for an inexpensive beater for a backup. Personally I use an XSi as a backup, otherwise, I'd just use a 5D Classic if you wanted a full frame backup.
Or for $1000~1500 more, you could get a 6D, if you plan on moving to full frame regardless. It just depends on what you're planning on shooting the most.
Very best,
hollis_f
May 01, 2014 06:34 |  #3
If it were me I'd get a second-hand 60D (uses the same batteries as the 7D) and sell it for little, to no, loss on my return.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
Aus.Morgo
Joined Feb 2012
May 01, 2014 07:59 |  #4
I'm heading off for a trip during June and July, mostly in Botswana. I'm taking 3 bodies.
I like the idea of having a short, medium and long setup so I can just put down one and pick up the other with out hopefully changing a lens all day which will really help keep the dust issues to a minimum.
Jim_T
Joined Nov 2003
May 01, 2014 09:46 |  #5
I was in South Africa last February and managed to go on a safari in an open Toyota Land Cruiser.. I took my 7D and 100-400L. I was very happy with the pictures that combo produced. (see below) .
For a second body, I used a Sony NEX with an 18-55mm zoom. (I would have liked an EOS-M but got a better deal on the Sony).
This is the first time I've used two cameras in a fluid situation and it really helped. The small size of the NEX allowed me to comfortably hold it in my lap in a bouncing vehicle and quickly switch cameras rather than having to take the time to switch lenses when I needed a wider angle.
You'll really enjoy the trip :)
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/05/1/LQ_684095.jpg
Image hosted by forum (684095) © Jim_T [SHARE LINK]
zzmorris
Gallery: 14 photos
May 01, 2014 09:57 |  #6
Definitely have a second body as back up. The second day on safari, your camera packs up/stolen/dropped. Also, you can put your 50 on it for a wider angle.
William
Gear List Canon 70D, Canon 40D, Canon 70 - 200 2.8 IS, Canon 400 5.6
jaomul
Joined Apr 2011
May 01, 2014 10:02 |  #7
^^ great elephant shots.
I do agree with thw secondhand 60d suggestion, however for the most part you will likely be in good light so a cheaper and lighter xsi is a good idea also. Taking to much can also take from enjoying the experience
Olympus EM5,Nikon d7200,
Olympus 12-50mm, 40-150mm,17mm f2.8,Nikon 50mm F1.8, Tamron 90mm vc, 18-105mmVR, Sigma 18-35 f1.8
PIXmantra
May 01, 2014 10:11 |  #8
Just came back from it...
...Only had one (1) 1D MarkIII body, and ended up using two lenses. My wife did take her 70D, but (beyond redundancy), it is a really good idea to take two bodies, with two different "reach" sweet-spots, so you can capture anything that shows up on your way. It is certainly a wise advice. Three cameras is also great (but there will be weight restrictions on charter-flights, therefore two cameras, with well tuned lenses will serve Ok.)
Some pictures (right in front of Kruger National Park, in private reserves):
https://photography-on-the.net …p=16873904&post​count=8526
Enjoy the trip!
Click here for FlexNR-Professional Noise Reduction for EOS 1D3
CPS Member/ 2x1DMKIII/ 70D/ Pentax MX
300mm f/2.8 L II IS/ 24mm f/1.4 L II/ 35mm f/2.0 IS/ 17-40 f/4 L/ 24-105 f/4 L IS / 70-200 f/4 L IS
270EX/ 580EX/ 580EX II/ ST-E2/ CP-E3
HP Z800 x2 XEON, x12 Core/ EIZO CG241W/ Viewsonic VP930b
ken_vs_ryu
May 01, 2014 14:56 |  #9
Not switching lenses is the main advantage of using 2 bodies.
http://google-black.blogspot.com (external link)
Cassiedup
Joined Sep 2011
May 01, 2014 15:56 |  #10
ken_vs_ryu wrote in post #16875378 (external link)
A big +1
5D MK IV 80D 17-40L, 70-300L, 300 F2.8L, 500 F4L, 100 F2.8 L Macro Sigma 150-600 S
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
May 01, 2014 16:26 |  #11
Your long Zoom makes it easier to work with one camera, but I'd still want two bodies.
The 120-300mm on one, and something in the wider end of things on the other.
Being able to go from this;
IMAGE: http://jakehegnauer.zenfolio.com/img/s4/v66/p1422591818-4.jpg
IMAGE LINK: http://jakehegnauer.ze​nfolio.com/p326415976/​e54cb074a  (external link)
to this,
IMAGE: http://jakehegnauer.zenfolio.com/img/s11/v31/p1467975162-4.jpg
IMAGE LINK: http://jakehegnauer.ze​nfolio.com/p326415976/​e577f85fa  (external link)
......without fumbling to swap lenses is a fundamental requirement.
I notice you don't have that sort of lens either, with 50mm prime being your widest, so Jim_T's suggestion is even more on target for you.
Otherwise, a 2nd body and a zoom like the 24-105 or even 17-40mm might be worth considering. Or one of the excellent affordable EF-S zoom options.
I for one rarely try to shoot with just one body in situations where I need to react fast. For Africa I always had two bodies at the ready. Ideally, if I had the space and cooperation of those around me, I'd actually have three.
A long prime, a long zoom, and a wide /mid zoom. But three is very hard to manage.
CDS' HOT LINKS
powaysteve
May 01, 2014 16:48 |  #12
I was in Botswana and Zambia in 2012 and took 2 bodies. Never switched lenses in the field and that saves you a big dust headache. Also when you are onto an animal you don't want to waste time and switch out lenses, you want to shoot. If you have one body with telephoto and one with a wide angle or zoom, you can get different perspectives on the same animal.
Buy a used body or save up for that 6D you want. The ideal situation would be the 7D with a telephoto and a full frame with a wide angle zoom.
tonylong
...winded
Gallery: 60 photos
May 01, 2014 17:40 |  #13
I think that if it was me, my first thought would be to have the ability to shoot wide, looking to capture the scenic/landscape aspects, even though when we think about that type of trip we think "critters"!
As such, getting a wider lens for the 7D, or if you do decide to get the 6D as a second body, then the "full frame kit lens" (the 24-105) can be invaluable, keep it on the 6D and keep the longer lens(es) on the 7D...?
Tony
Africanphoto
Joined Sep 2012
May 02, 2014 00:00 |  #14
I have the samyang as a wide and angle, then the 50 sigma and a canon 100L so I think I'm pretty covered. I honestly can't fit another lens in my bag nor do I feel as if I need another lens
griffljg
Gallery: 146 photos
Joined Dec 2013
May 02, 2014 00:34 |  #15
I was in South Africa in Oct / Nov 2012 attending an old high school reunion. An old mate suggested that we pay a 5 day visit to the Kruger Park. There had been a lot of rain recently and so we weren't expecting to see very much and if we did see anything, we expected it to be fairly close. The first afternoon, we saw four of the BIG 5 and the following morning, we saw all 5.
I was carrying mainly Olympus gear (an E-3 with an E-300 backup), but found that I was using the 70-300 zoom most of the time. - This is the equivalent of a 140-600 on a full-frame camera.
This photo was taken at 300mm:
IMAGE: https://lh5.googleusercontent.com/-7EXSeQUbtxs/ULkVTdJCmII/AAAAAAAB_30/RSg2PsApURk/s800/PB260366.jpg
My advice is therefore, if you are going to take an EOS-6D, at the very least, take a 100-400 zoom with you. That is why I have bought one.
Larry
OM System OM-1 | Olympus OM-D E-M1 Mark III | Olympus OM-D E-M1 Mark II | Olympus OM-D E-M1 | Olympus M.Zuiko DIGITAL 12-45mm f/4 PRO | Olympus M.Zuiko DIGITAL 12-40mm f/2.8 PRO | Olympus M.ZUIKO DIGITAL ED 12-100mm f/4 IS PRO | Olympus M.Zuiko Digital ED 100-400mm f/5.0-6.3 IS
6,389 views & 0 likes for this thread, 21 members have posted to it.
Going to africa.
1095 guests, 173 members online
