Thread started 02 May 2014 (Friday) 22:01
HSS with Fuji X-T1
jaycharles
Joined May 2014
May 02, 2014 22:01 |  #1
Hello,
I am making a switch from Canon to Fuji for the X-T1. I am curious if there is a way to use higher sync speed or preferably HSS with small flashes? I currently have 600-EX-RT flashes but I will off them if they can't do some kind of higher speed syncing with the Fuji. I am wondering if Godox, Yongnuo, etc offers a solution for this?
Thank you kindly. Charles
dmward
Gallery: 29 photos
May 02, 2014 22:07 |  #2
Charles,
I also have X system gear, as well as Canon.
Except for the Fuji ETTL speedlite, which has limited capabilities there are no other options readily available.
Lots of manual options but no real ETTL options that I've found.
HyperSync may be available but even that usually requires a trigger on the camera that can deliver the FP sync signal. Which Fuji can not deliver to non-Fuji flash units.
jasonckeen
1 post
Joined Aug 2013
May 03, 2014 09:32 |  #3
dmward wrote in post #16878549 (external link)
Charles,
Thanks!
What are the issues with Fuji's ETTL?
Is there a way to do ETTL off camera with Fuji's flashes?
v35skyline
May 03, 2014 10:58 |  #4
With a Fuji TTL flash and a Canon ETTL cord, I believe you can.
X100s | X-Pro1 | X-T1 | XF 14 | XF 18 | XF 35 | XF 56 | XF 60 | XF 10-24
Gear List & Feedback
jaycharles
Joined May 2014
May 04, 2014 12:21 |  #5
v35skyline wrote in post #16879324 (external link)
That's awesome! If it does ETTL does that mean it will do HSS as well with a cord?
v35skyline
May 04, 2014 13:35 |  #6
Not that I'm aware of as HSS is a Canon feature.
jaycharles
Joined May 2014
May 04, 2014 16:13 as a reply to  @ v35skyline's post |  #7
Alternatively, can anyone suggest a flash and radio that this long burn or "hypersync" style of HSS might work well enough for the Fuji?
dmward
Gallery: 29 photos
May 04, 2014 22:30 |  #8
Charles,
The key to HyperSync, is getting the camera to send an FP sync signal. That requires a trigger that will recognize the signal from the control pad on the camera. To my knowledge that would require a Fuji specific trigger.
starlights
Gallery: 16 photos
Joined Apr 2011
May 10, 2014 16:56 |  #9
Down the line, I plan to get a XT-1 as well, so I will watch this thread with interest....
dmward
Gallery: 29 photos
May 10, 2014 22:02 |  #10
I have a battery powered strobe coming for some testing.
It uses voltage control for power management so it will work in a HyperSync situation.
I am planning to test it with my X system cameras to see how it works doing HyperSync.
jaycharles
Joined May 2014
May 10, 2014 23:11 |  #11
dmward wrote in post #16896119 (external link)
Please lemme know how it goes -- very interested. Thanks!
BluPace
1 post
Joined Jun 2015
Post edited over 8 years ago by BluPace.
Jun 28, 2015 05:34 |  #12
I have just purchased the Fuji Xt1 and I think I will also purchase a Cactus RF60.
It has HSS Sympathy mode.
The HSS Sympathy mode of the RF60 is designed to support flash photography at shutter speeds beyond a camera’s maximum sync speed. With the help of a TTL flash mounted on camera, RF60 fire flashes with an extended duration in order to produce even frame illumination at shutter speeds as high as 1/8000 second.
The included EF-X8 Flash that comes with the XT1 is I believe a TTL flash, so you could use this on camera to fire the RF60.
Hope this helps...
5,896 views & 0 likes for this thread, 6 members have posted to it.
HSS with Fuji X-T1
1283 guests, 129 members online
