I know the 20D can save these two file at the same time but can the Rebel? If so, how much memory does this each picture take up? What size of memory do you need and aprox. how many pictures will they hold? (RAW and JEPG) and (JEPG only)
deepsouth Junior Member 23 posts Joined Feb 2006 Location: TN More info | Feb 12, 2006 08:37 | #1 I know the 20D can save these two file at the same time but can the Rebel? If so, how much memory does this each picture take up? What size of memory do you need and aprox. how many pictures will they hold? (RAW and JEPG) and (JEPG only)
Sageg Senior Member 521 posts Joined Oct 2005 Location: Montreal More info | Feb 12, 2006 08:39 | #2 The XT can take raw & jpg at the same time. Not sure about the original digital rebel. Sarah
kram obvious its pointless 2,612 posts Likes: 3 Joined Feb 2005 More info | Feb 12, 2006 09:03 | #3 Yes, the Rebel can save RAW + Jpg. In fact, when you save RAW, it always has an embedded jpg. With the hack, you can also choose what size the jpg has to be. Else, I think it saves RAW + Big Jpg. Canon 7D , Canon 6D, 100-400 L, 24-105 F4 L, 50 F1.4, Tokina 12-24 F4, Kenko Teleplus Pro DG 1.4X Extender
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Feb 12, 2006 10:07 | #4 The embedded JPEG in the RAW files of the Digital Rebel (300D) is "medium" size (2048 x 1360 pixels). Use the EOS Viewer Utility software that comes with the camera to extract the JPEGs. The files will average around 7 megabytes. You'll get around 140 shots on a 1 gigabyte CF card. "If you're not having fun, your pictures will reflect that." - Joe McNally
Bodog Goldmember 1,306 posts Joined Feb 2004 Location: Peculiar, MO More info | When set to "RAW" the 300D will only record RAW plus JPEG. The JPEG can't be turned off. With the hack you can change the JPEG size. Setting the size to small, the camera indicates 163 images available on a 1GB card, though I've never tested to see how many can actually be recorded. Suppose the final count will vary, depending on ISO and subject matter. JimE
JasonMX Senior Member 319 posts Joined Nov 2004 More info | I was under the impression that the if you did RAW and JPEG, the JPEG had to be set to a lower quality then just saving as JPG. Is that true? Surf to http://blog.outphishing.com
Bodog Goldmember 1,306 posts Joined Feb 2004 Location: Peculiar, MO More info | OOB, the settings cannot be altered. Set on RAW, the camera records the raw and medium quality jpeg. There is no other option. JimE
JonFoster is it safe? 4,521 posts Likes: 39 Joined Feb 2005 Location: White Lake, MI More info | Jun 02, 2006 23:25 | #8 How does the 1D series camera record RAW and JPG files? Are they saved on the card as two separate files or is the JPG file stored in the Raw file like the 300D and must be extracted later? I shoot with a Little Canon
NordieBoy Goldmember 2,635 posts Likes: 1 Joined Jan 2006 Location: Nelson NZ More info | Bodog wrote: OOB, the settings cannot be altered. Set on RAW, the camera records the raw and medium quality jpeg. There is no other option. Unless you are using the Wasia or UnDutchables hacks. Fran
| Latest registered member is Thunderstream 1866 guests, 108 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
