Thread started 03 May 2014 (Saturday) 09:40
Best soccer settings for 5D mk3??
Nick_Reading.UK
Joined Nov 2011
May 03, 2014 09:40 |  #1
Hi..
What are the best setting for soccer/Football?
Shooting with a 70-200 2.8 mk2..
AF menu case number?
AI servo 1st and 2nd image priority?
Picture style?
Aperture ?
Metering mode?
AF area selection?
Or anything else I forgot??
Thanks...!
EOS 5Dmk3 X2, 60D, EF24-70mm f2.8L mk2, EF70-200mm f2.8L IS mk2, EF85mm f1.8, EF50mm f1.4, EF50mm f1.8 mk1(350D with 18-55mm Sh"kit" lens).
Speedlite 600EX-RT, 430EX II Flash. manfrotto 190XDB tripod, Giottos GTMML 3290B Monopod, B+W 77mm 110 Single Coated filter, Hama 77mm Variable Neutral Density Filter.
sandpiper
May 03, 2014 10:07 |  #2
Nick_Reading.UK wrote in post #16879210 (external link)
Hi..
AF menu case number? I would suggest maybe case 6 as soccer players move quite erratically at times and can suddenly stop and change direction. But I might play with individual parameters myself. I would certainly turn down the tracking sensitivity a little, if using case 6.
AI servo 1st and 2nd image priority? I would go with it cranked right over to focus on both, as I am only interested in sharp shots. If shooting for the press I would go the other way, as newsprint doesn't demand ultimate sharpness but capturing the best moment is key.
Picture style? Well, I would be in neutral, to keep my histogram accurate, but I don't shoot jpeg. Which you choose depends on how you want your image processed, and that is down to individual taste. Personally, I do my processing later, rather than let the camera do it.
Aperture ? Depends on what you want from each shot. Typically, I would go f/2.8 to keep the background out of focus, but for some shots I might want more DOF and shoot accordingly.
Metering mode? Depends on conditions, personal taste and what mode you are shooting in. I would tend to take a reading from the grass and base my (manual) settings on that. If shooting a semi-auto mode then maybe EV mode and watch out for white shirts etc. which may require some EC.
AF area selection? Single point, selected according to where in the frame my subject will be.
Thanks...!
These are just suggestions though, there are no "best" settings, just settings which suit the conditions at the time and will give you the result you are after. The whole art of photography is previsualising how you want an image to look, and using settings to give you that look. You may want a different style of result to me, or the next person to answer.
Rather than ask what settings to use, it is better to learn how the settings affect the result, then you can choose the right ones for what you wish to achieve with each shot. I will generally change most of those above as the shoot progresses as I go for different shots, and want a specific look to the shot that is different to the ones before.
Nick_Reading.UK
Joined Nov 2011
May 03, 2014 10:13 |  #3
Cheers mate. Next time I am up Mathew street I will buy you a beer ., :-)
Nick_Reading.UK
Joined Nov 2011
May 03, 2014 10:30 |  #4
sandpiper wrote in post #16879243 (external link)
I do that anyway, but it's nice to have a starting point..
1,089 views & 0 likes for this thread
Latest registered member is dm19dm
1680 guests, 314 members online
