Thread started 04 May 2014 (Sunday) 10:39
Which goes on first?
chrisr09
Joined Jun 2011
May 04, 2014 10:39 |  #1
If I'm going to use a CP and a solid (6-stop) ND filter at the same time, should I put the ND on first so I can adjust the CP to accommodate the scene? That seems to make the most sense to me, but somewhere I read a person complaining that you had to adjust your CP first, make note of the position, before screwing on your ND filter.
I don't have either filter yet, so I have no experience with either.
Christine ~ My Flickr (external link) ~ My Fine Art America (external link)
Canon 5DIII & Canon 7DII ~ Canon 16-35mm f/4L ~ Canon 100mm f/2.8 Macro USM ~ Canon 24-105mm f/4L ~ Canon 400mm f/5.6L USM ~ Tamron 70-200 f/2.8 Di VC USD ~ Rokinon 14mm f/2.8 ~ Canon Speedlights 430 EX & 430 EXII ~ Induro CT-213 tripod ~ Acratech GP ballhead
Jon
Joined Jun 2004
May 04, 2014 10:58 |  #2
A solid (not graduated) ND is non-directional; it shouldn't matter which order you put them on as far as your camera and lens are concerned. You, however, might find it easier to adjust the CPL with the ND off, note the orientation, and then attach the ND and re-check the CPL orientation. With 6 stops of ND + 1-2 stops from a CPL you won't be seeing a whole lot except maybe via Live View, when you try to adjust the CPL with both on.
Jon
Cocker Spaniels
chrisr09
Joined Jun 2011
May 04, 2014 18:00 |  #3
Thanks Jon. That makes sense how you explained it. I might start out with just a CPL and work from there.
NCSA197
Gallery: 153 photos
Joined Dec 2011
May 06, 2014 17:11 |  #4
Jon wrote in post #16881138 (external link)
This is EXACTLY what has worked well fro me. I enjoy waterfalls, and the two filters together give me the look I prefer. The "work-flow" Jon describes is really not time consuming and you can see what you are setting up.
1,013 views & 0 likes for this thread, 3 members have posted to it.
1325 guests, 109 members online
