Thread started 04 May 2014 (Sunday) 11:10
Elinchrom D-lite RX 400
LensNV
Joined Dec 2011
May 04, 2014 11:10 |  #1
Hi all. Could do with some advice. I've just bought the Elinchrom D-lite RX 400 studio kit and I seem to be having a slight issue with sync speed. I'm running a Canon 5D mkiii which I put on a shutter speed if 200. I pop the lights into high speed sync but I still seem to get a slight grey band at the bottom of my images. If I drop the ss to 160 then it doesn't seem to be an issue. It may just be light fall off but if I turn the camera to portrait orientation and take a shot it happens on the right side of the image. Is it a sync speed issue? Can you advise me please.
Simon
C-pix
May 05, 2014 15:38 |  #2
Yes, it is a sync speed issue.
What do you trigger the strobe with? Cable or radio trigger?
/Christer
www.c-pix.nu (external link)
www.facebook.com/c-pixphotography (external link)
nathancarter
Gallery: 32 photos
May 05, 2014 18:52 |  #3
Yep. Turn your shutter speed down to 1/160.
Using the 5D3, I've not been able to get 1/200 reliably with either Skyport (Elinchrom) or with Cactus V5.
Sorry.
rdwalton
May 05, 2014 18:59 as a reply to  @ nathancarter's post |  #4
You should be able to get 200 with the cable trigger. I have the 5D II and an off brand strobe and I can get 200 if I use the cable to trigger the strobe. If I use my Pocket Wizard Plus III or my Yongnuo 603C, I can only get 160.
Reginald D. Walton | GEAR | Smugmugexternal link
Eyal
Joined May 2011
May 07, 2014 05:51 |  #5
I have the RX 4 and 5D3. Anything above 1/160 will give you the blackish line because the skyport does not sync fast enough. This is a known issue with the skyport with anything but their top model.
If I need faster shutter speeds, I use the pixel king transmitter/receiver. They allow high sync speeds and work great with the RX 4s and sync correctly even at much higher speeds (the fastest I needed and tested was at 1/2000 and it worked well).
They also allow me to use a speedlight along with the elinchrom if I need something small for filling.
5DMarkIII+Grip | Extender 1.4x III / 2x III
16-35mm F/2.8L II | 24-70mm F/2.8L II | 70-200mm F/2.8L IS II
Σ 50mm F/1.4 | 85mm F/1.2L II | 100mm F/2.8L IS Macro | 135mm F/2L | 300mm F/2.8L IS
johnbellerose
Joined Nov 2013
May 07, 2014 13:08 |  #6
is that including Speed skyports too?
John Bellerose
www.johnbellerose.com (external link)
Eyal
Joined May 2011
May 07, 2014 14:16 |  #7
johnbellerose wrote in post #16888530 (external link)
Well, as far as I know, there is only one transmitter, which is the normal EL-Skyport Speed.
Activating the speed more (pressing TEST button for 5 seconds if you hadn't, else its on normal mode and more than explain your problems) will enable sync speeds to 1/250 and maybe higher (not officially but a few people said that it will).
But from my experience, its sometimes unreliable. So I prefer using better proven transmitters.
Just make sure its actually in speed mode.
xrayhead
May 08, 2014 04:13 |  #8
Doesn't Pocket wizard do a module that allows the use of HyperSync? https://www.youtube.co​m/watch?v=-pPHNcZ0AYQ (external link)
Not sure what shutter speed you are looking for but the PW go's way above 1/200
Website (external link)
Eyal
Joined May 2011
May 08, 2014 05:48 |  #9
I'm sure many external syncs allow this. Problem is that when elinchrom advertise sync speeds which are not always reliable, you feel a bit cheated into having to buy external transmitter and receivers.
phreaknes
Joined Jun 2011
May 08, 2014 10:43 |  #10
Make sure the head is in speed mode. Make sure it's in R2
Poor is the man whose pleasures depend on the permissions of another.
______________
Kata Lighting bag for sale. Click here for details
Gear list
say_cheese
May 09, 2014 11:21 |  #11
Use the old fashioned flash sync cable that came with your RX, that should solve the problem, or at least improve it. Why do you need the 200ss anyway?
Tools: I like things with real dials and knobs.
4,054 views & 0 likes for this thread
Latest registered member is jabes001
938 guests, 323 members online
