I bought one tried it, it was used but what in the world happened? Shot this in Auto mode no detail and very noisey....
http://www.jenshep.com/Jens-Eyes/i-MjDXqqR/A![]()
Marco315 Member 213 posts Likes: 1 Joined Oct 2012 More info | May 04, 2014 18:10 | #1 I bought one tried it, it was used but what in the world happened? Shot this in Auto mode no detail and very noisey....
teekay Goldmember 3,037 posts Likes: 799 Joined Apr 2001 Location: British Columbia, Canada More info | May 04, 2014 18:37 | #2 Could you post the photo directly to this forum so that we can see the EXIF info and maybe spot the problem?
May 04, 2014 19:45 | #3 teekay wrote in post #16881988 Could you post the photo directly to this forum so that we can see the EXIF info and maybe spot the problem? Teekay, not sure on how to upload them here so I made a gallery http://www.smugmug.com/gallery/n-JGMk7/i-bQLLdcQ/A
Max98 Hatchling 7 posts Likes: 1 Joined May 2012 More info | May 05, 2014 04:59 | #4 From the exif : Digital zoom 3.1x
May 05, 2014 09:16 | #5 Max98 wrote in post #16882866 From the exif : Digital zoom 3.1x Elaborate for me Max, was it out of focus on the wrong zoom?
teekay Goldmember 3,037 posts Likes: 799 Joined Apr 2001 Location: British Columbia, Canada More info | Marco315 wrote in post #16882099 .... Smigmug...look for the i symbol at the bottom and it will give the EXIF info... Thanks - I never noticed that feature is available on the site even though I use Smugmug myself.
May 05, 2014 13:00 | #7 teekay wrote in post #16883542 Thanks - I never noticed that feature is available on the site even though I use Smugmug myself. As Max98 has noted, you were using digital zoom in that photo and explains the loss of quality. Many people disable that feature on their cameras since digitally zooming merely magnifies the image by inserting pixels (sort of). For example, look at any image on your computer and then zoom in more and more using your image editing program (or browser zooming function etc.) and you will see the quality decrease as the image grows bigger and bigger on the screen - that's "digital zoom". so to make sure my dumb butt understands if you use digital zoom you get distortion and noise. So how in the world would you zoom a G15 without using the digital zoom? Smugmug is great been using it for years. Thanks for the help.
May 05, 2014 13:17 | #8 Marco315 wrote in post #16883707 so to make sure my dumb butt understands if you use digital zoom you get distortion and noise. So how in the world would you zoom a G15 without using the digital zoom? Smugmug is great been using it for years. Thanks for the help. Read pages 63 and 81 in your user guide. Canon used to include a chart showing the digital zoom ranges, as well as explaining the Yellow and Blue range indicators better.
May 05, 2014 14:08 | #9 denncald wrote in post #16883739 Read pages 63 and 81 in your user guide. Canon used to include a chart showing the digital zoom ranges, as well as explaining the Yellow and Blue range indicators better. Dennis Thanks Dennis I see what I did wrong now. I bought that camera used it came with nothing no manual, no software, no USB cable, nothing but a battery and charger. I'm so use to shooting my SLR getting use to PS is different.
May 05, 2014 14:11 | #10 Marco315 wrote in post #16883874 Thanks Dennis Also see the Edit I just added before you posted your reply. You're welcome. You are just basically cropping the sensor in-camera with digital zoom, so most recommend shooting max optical zoom plus RAW, and then crop in your photo editing software on your computer. I've taken some good Jpeg digital zoom results, but it helps to have good lighting. This is from using my G9 with a 2.0x tele lens at max zoom, plus 2.0x digital tele zoom = 840 mm equivalent (210 mm x 2 x 2), Dennis
teekay Goldmember 3,037 posts Likes: 799 Joined Apr 2001 Location: British Columbia, Canada More info | May 05, 2014 18:17 | #11 Marco315 wrote in post #16883707 ....So how in the world would you zoom a G15 without using the digital zoom?.... Turn on your G15 and set it in AUTO. Now use the zoom lever and you will see the lens moving back and forth, optically changing the focal length - i.e. optically zooming, and on the LCD screen you will see the white line at the top (zoom indicator) moving back and forth.
May 05, 2014 20:56 | #12 teekay wrote in post #16884462 Turn on your G15 and set it in AUTO. Now use the zoom lever and you will see the lens moving back and forth, optically changing the focal length - i.e. optically zooming, and on the LCD screen you will see the white line at the top (zoom indicator) moving back and forth. Then if you keep zooming in past the 5x optical zoom limit you will see the zoom indicator change colour to yellow and finally blue but the lens isn't moving. That shows you are digitally zooming past the optical limit up to about 20x and your resulting image will be getting progressively grainier. When in AUTO mode you can disable digital zoom - it's the first option in the shooting menu. Thank you so very much
| Latest registered member is MWCarlsson 1149 guests, 178 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
