BearLeeAlive wrote:
Would this vibration be lessened by using a carbon fiber model?
the main reason for Carbon fiber is to reduce vibration, the lighter weight is very much a minor, secondary reason. so yes, it will certainly help. In fact I did a test with my Manfrotto where I eliminated the CF center column and use the stubby plastic fitting to attach the ballhead to. Using a long lens with or without MLU I saw more vibration without the center colum than with it. Go figure, but my hypothesis is that the CF center column couples the CF leg mass to the ballhead better than without the column.
When I do macro with the Gitzo explorer, I often use the camera L bracket from the side, or with the camera hanging upside down and somehow don't see using a Pan head in a non vertical orientation. For that matter I don't know of any pan heads that use Arca Swiss, but one could put a AS clamp on top of another clamp/QR plate. Certainly AS style clamps come built on focusing rails, but they would have to be attached via screw or AS plate to the pan head. I also use an angle finder c at any angle available as I am usually very close to the ground.
Mike K
