Thread started 05 May 2014 (Monday) 20:36
Elinchrom Deep Octa question
MFG
May 05, 2014 20:36 |  #1
Hi,
i just got my Elinchrom Deep Octa 100cm the bigger one. Using it for my Quadra.
Regarding the diffuser, i like to know how people are actually using it to get the best results;
1. do you remove the diffuser cap that came with the flash head? I think i will remove that.
2. the Elinchrom deep octal comes with two cloth-like diffuser, one clip onto the centre, the other velco to the outset rim of the soft box, do you have them both at the same time?
3. it also came with a Translucide deflector set (no.1). do you use it too?
I am still waiting for the reflector adaptor to arrive.
perhaps any photos of the inside of your deep octa will helps.
thank you
AIPP Accredited (Australia), WPJA
Professional Wedding, Newborn and Family Photographer
https://www.scottgohph​otography.com.au (external link)
https://www.facebook.c​om/ScottGohPhotography (external link)
https://www.scottgohph​otography.com.au/blog (external link)
https://www.scottgohph​otography.com.au/babie​s-and-children/ (external link)
sdipirro
May 06, 2014 10:39 |  #2
For indoor, studio shoots, I use a reflective deflector and both inner and outer diffusers. Although I've swapped the translucent deflector with the reflective one in this configuration and didn't really notice any difference. When shooting outdoors, I sometimes don't want to limit the power by using both diffusers, but it also depends on the wind. I'll use the front diffuser if it's particularly windy. If it's not, I might shoot with just the inner diffuser. I always use a deflector...and have shot with just the deflector and no diffusers for more of a beauty dish type of look. I don't even have diffuser caps for my flash heads and have never used them (except for the Profoto B1). There are lots of combinations to try. I'd suggest that it's time to play around and see what suits your tastes.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
MFG
May 06, 2014 20:59 |  #3
Thank you sdipirro. good info.
I will try it when the reflector is here.
Eyal
Joined May 2011
May 07, 2014 05:29 |  #4
I have been shooting with a borrowed one for a bit using it with the RX 4.
For studio, I usually use both inner and outer, and sometimes I'm using the hooded if I want a bit less light in all directions.
Outdoor I'm only using the outer or hooded, but without the inner one.
5DMarkIII+Grip | Extender 1.4x III / 2x III
16-35mm F/2.8L II | 24-70mm F/2.8L II | 70-200mm F/2.8L IS II
Σ 50mm F/1.4 | 85mm F/1.2L II | 100mm F/2.8L IS Macro | 135mm F/2L | 300mm F/2.8L IS
parkerik
Joined Dec 2013
May 07, 2014 05:33 |  #5
And I use only the innen one when I`m outside shooting, because I only got 400W.
If I want soooft ligth in studio I use them all.
seres
Joined Apr 2013
May 07, 2014 18:06 |  #6
I've been using the big and small Deep Octas with the Profoto Acute/D4 heads.... like sdipirro, I always use the plastic Elinchrom deflector, but not the inner and outer cloth diffusers. Quick and easy to setup on location.
—Eric
EOS_JD
May 07, 2014 20:52 |  #7
Mix it up. Depends on the power you need. You can't use with the quadras reflector. You need to use the Quadra to EL converter to use any EL fit modifiers.
THe deflector I use most of the time unless I need every ounce of power
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
2,241 views & 0 likes for this thread, 6 members have posted to it.
Latest registered member is EBiffany
959 guests, 111 members online
