Thread started 10 May 2014 (Saturday) 19:45
what did they do to my 5d3?
ed ­ rader
"I am not the final word"
May 10, 2014 19:45 |  #1
I had my 5d3 cleaned professionally last week. today when I went to use it the camera does not AF. there's no lit box or confirmation beep yet in one-shot the camera will fire but the picture of course is not in focus.
of course the shop is saying there's nothing they did that could have caused the problem, but I've never had any problems with this body and it did work when I took it in and now does not work.
I've tried different lenses and batteries and at the shop they even pulled the button battery to reset the camera. still does not AF.
anyhow they will send the 5d3 to canon on Monday and I believe there's a 50/50 I will get stuck with the repair bill.
so what could have happened?
thanks
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
CollegeKid
Joined Mar 2014
May 10, 2014 20:21 |  #2
I am guessing they were a bit over-generous with a cleaning solution. A week seems like enough time to dry out, though. THEY sent it to Canon? THEY, if they value their reputation at all, will be paying the bill. Even if they don't value their reputation, a notice to appear in a small claims court, and all the attendant poor publicity should make them see the light. I don't think you'll have to go that far.
Sgt, ­ Mike
Joined Apr 2011
May 10, 2014 20:45 as a reply to  @ CollegeKid's post |  #3
Is it possible they may have changed your AF settings & switched them to back button AF?
7D, 5D III - 70-200 f/4L IS, 28-135, 24-105 f/4L IS, Tamron 17-50 f/2.8, Tamron 70-300 f/4-5.6 VC, Tokina 16-28 f2.8, Tamron 1.4x TC, Nifty Fifty
ed ­ rader
May 10, 2014 20:53 |  #4
Sgt, Mike wrote in post #16895988 (external link)
Mike -- we checked everything but that is something I thought of too. we restored all the settings to factory. I spent two hours in the service department and the store's main canon guy and i tried everything. something was damaged
julianthebest611
Joined Jun 2012
May 10, 2014 20:54 |  #5
Perform a full factory reset...really weird that they changed to BBF.
50D, T3 (still in the family, but given to my sister), T3i 18-55mm IS II, 50mm 1.8 II, 55-250mm IS II, 75-300mm III, 28-135mm IS USM. 430 EX II, 550 EX, YN-560 II
ed ­ rader
May 10, 2014 20:54 |  #6
CollegeKid wrote in post #16895957 (external link)
hmmm I hadn't thought of that. good one. actually the sensor was cleaned on Thursday so it has only been two days.
ed ­ rader
May 10, 2014 20:58 as a reply to  @ ed rader's post |  #7
funny thing is I've used this camera in all sorts of conditions for the past 15-16 months and i change lenses a million times a day no matter where I am at and I have never seen a single dust speck on any image! but I figured I'd get the camera cleaned because these guys always do a great job and we're headed on a road trip next month and I have a couple of trips lined up afterwards.
also, this is the first time in years that I have been without a second DSLR but I did order a SL1 last week so i'll get it Thursday.
so the lesson here is always have a back-up camera and never get your gear serviced at the last minute
ed ­ rader
May 10, 2014 21:02 |  #8
julianthebest611 wrote in post #16896004 (external link)
I specifically told them not to **** with any of my settings. once someone set my camera to jpeg and I didn't realize it till several hundred frames later.
well it's all been wiped clean now and ill bet there will be a hefty repair bill as well
julianthebest611
Joined Jun 2012
May 10, 2014 21:27 |  #9
It's like when I take my car for an oil change! They move my seat and it takes forever to put it back again!
InfiniteDivide
"I wish to be spared"
Gallery: 265 photos
Joined Dec 2013
May 10, 2014 21:46 |  #10
Sorry to hear of your troubles, I maintain my own gear.
I fear something like this happening if I send it off to someone else.
James Patrus
6D | 16-35L F4 | 24L II | 50L | 100L | |  -> Website (external link) & Gallery (external link)
Do you enjoy Super Famicom games? (external link)
Frodge
Joined Nov 2012
May 10, 2014 21:58 |  #11
Wow. That really sucks. I would be pretty angry given the reason I brought it into the shop, only being a cleaning. I am in no way bustig your chops, but this is one of those old lessons where if t ain't broke.....(I see you mentioned there were no specks in photos) sorry for the bad luck.
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
ed ­ rader
May 10, 2014 22:11 |  #12
InfiniteDivide wrote in post #16896087 (external link)
do you do your own root canals :D? c'mon man this is the biggest store in the south san francisco bay area. I've had many cameras cleaned there over the years.
it was just a routine cleaning but something went wrong and I am trying to get some ideas on what could have gone wrong.
ed ­ rader
May 10, 2014 22:13 |  #13
Frodge wrote in post #16896107 (external link)
N2bnfunn
May 10, 2014 23:04 |  #14
They just put it back to the factory setting....You have to go into custom function and select everything over again
Canon EOS R EF 70-200 L 2.8 L 24-70 2.8L II Canon Pixma PRO-1 3 Canon 600EX-RT Speedlites
tonylong
...winded
Gallery: 60 photos
May 11, 2014 00:15 |  #15
N2bnfunn wrote in post #16896226 (external link)
The Canon Service Center does this, and it can throw you off, especially if you are set to back button focus.
But it doesn't sound like this was the case here. In One Shot mode the shutter shouldn't fire if focus is not obtained (and locked). It sounds like something is amiss here...
Ed, the only thing "normal" that might cause this would be if you had your lens set to Manual Focus...but I'd imagine that would be determined by you and/or the shop...
Tony
16,105 views & 0 likes for this thread, 30 members have posted to it and it is followed by 3 members.
1523 guests, 132 members online
