Thread started 12 May 2014 (Monday) 00:52
Need a very very low stand
abbypanda
Joined Nov 2011
May 12, 2014 00:52 |  #1
I got a strobe awhile back. (einstein) and I like to do a lot of pets.
Some pets are very small, and as I work with my einstein and my poodles I am coming up with a problem. Basically I need to light the small dogs on the ground…sometimes I like to lay down with them and shoot up, get the sky, etc.
Well, no light stand will drop the light low enough. I could sit it on the ground but it's akward and wouldn't work quite like I wanted, not to mention hazardous. Is there some sort of stand I can get that basically barely raises the light off the ground, but still provides the same "benefits" of a regular stand. Thanks in advance
fashionrider
Joined Dec 2011
May 12, 2014 00:54 |  #2
You could always purchase a stand with a boom arm. The boom arm can be pointed down so that the light can be as low as you want. Well, that's what I do at least.
Gear List (5D3, 70-200 f2.8L IS II, Sigma 85mm f1.4, Sigma 35mm f1.4, 50 f1.8, 24-105L, Alien Bee lights, etc etc)
SamFrench
Joined Jul 2011
May 12, 2014 00:59 |  #3
fashionrider wrote in post #16898334 (external link)
+1 bw! Excellent solution.
abbypanda
Joined Nov 2011
May 12, 2014 01:05 |  #4
Thanks I do not have one of those arms but good tips thank you.
Alveric
Gallery: 38 photos
May 12, 2014 01:13 |  #5
Something like this might be what you're looking for:
http://www.bhphotovide​o.com …Backlight_Stand​_with.html (external link)
Echo63
May 12, 2014 03:07 |  #6
Manfrotto do a short stand, it comes with a floor pod, baby pin spigot and extension pole
The baby pin would sit maybe 3" off the deck
Heres a link with a pic - you dont need the long extension, but it comes in the kit (prices are in aussie dollars too)
http://www.praimaging.​com.au …tudio+Accessori​es/pra0965 (external link)
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttps://photography-on-the.net …p?p=2463426&pos​tcount=385
VividLightPhotography
Joined Jan 2013
May 12, 2014 05:07 |  #7
ive used a box with the pet on the box, covered with a rug or carpet to get the pet up of ground level. With a low mouted light its still difficult to get the strobe at the right height.
hope that helps.
GearEos r, 5dmk3,RF 24-120 f4L, EF 24-70 f2.8 L, EF 70-200 f2.8 L, EF 17-40 f4L,, EF 24-105 f4L, , EF120-400 f3.5-5.6, Godox AD200PRO's , 600ex-rt, Elinchrom RX600, godox triggers and multiple receivers.
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
May 12, 2014 09:39 as a reply to  @ VividLightPhotography's post |  #8
i have two of these matthews stands http://www.bhphotovide​o.com …7486_Reverse_St​and_7.html (external link)
at the lowest setting, with a cheetah stand Qbox 24 and their standard bracket, the bottom of the box is 10 inches off the ground. That is with the bracket at a 90° angle to the stand and the face of the box virtually perpendicular to the ground. With the same set up and a slight downward tilt on the box, it is about 6 inches from the ground.
It works fine but a small boom or grip arm would be a better option that would allow you to put the stand a bit further out of your way.
FeXL
May 12, 2014 10:09 as a reply to  @ Left Handed Brisket's post |  #9
Studio Titan Side Kicks (external link)
Phototeacher
May 12, 2014 12:18 |  #10
How about a floor plate? They are often used with a ball head for remote camera mounting. It will definitely get you down to ground level.
http://www.msegrip.com​/matthews-baby-plates.html (external link)
Scatterbrained
Gallery: 267 photos
Best ofs: 12
May 12, 2014 12:35 |  #11
Are you planning on mounting any sort of modifier to the light? If so I'd avoid the backight stand and other background lighting solutions as they aren't too stable with a modifier mounted. One thing you can do is buy a small C-stand (20") (external link) and then you have a short C stand with a grip arm that will let you get the light below the head (just pick up a 6" baby pin (external link) for the grip head on the arm). You'll be able to get the light pretty much anywhere from the ground up with that set up. Want to put the light right on the top of the base? Just pick up a junior to baby (external link)adapter and you can remove the stand and mount the light right on the base. If you want to use a large modifier then the C stand will easily hold a solid boom arm (external link) too. ;)
500px (external link)
1x (external link)
instagram (external link)
Seamus69
Joined Nov 2010
May 12, 2014 12:41 |  #12
I have a short 12" tripod that the legs will go horizontal to the ground. I put a a stud on it and put my einstein on the stud. You will be limited by your modifier.
Canon 60D, 5Diii, 24-105, 24-70ii, 70-200 f2.8 ii is, 580ex, (2)430ex
jlt23
May 12, 2014 13:03 |  #13
I think the minimum height on this one is 1.7 ft. http://www.bhphotovide​o.com …10_Mighty_Baby_​Light.html (external link)
James
Luckless
Joined Mar 2012
May 12, 2014 15:19 |  #14
When working really low to the ground your biggest issue then becomes your modifier and how that is actually going to fit and be positioned. This is where a short boom art arrangement can come in handy.
A decent tripod actually makes a good base when dealing with modifiers close to the ground, especially with one that lets you adjust the leg angle independent of each other. Just make sure you have clips on the 'back' leg for a sand bag/counter weight.
Canon EOS 7D | EF 28 f/1.8 | EF 85 f/1.8 | EF 70-200 f/4L | EF-S 17-55 | Sigma 150-500
Flickr: Real-Luckless (external link)
Recondodk
Joined Oct 2013
May 12, 2014 16:37 |  #15
Those you can get really low.
http://www.bhphotovide​o.com …6019_Matthlink_​Stand.html (external link)
I love to shoot and I aim to please ;)
7,344 views & 0 likes for this thread, 21 members have posted to it.
880 guests, 128 members online
