Thread started 13 May 2014 (Tuesday) 12:04
What strap do you use with your battery grip?
jt354
May 13, 2014 12:04 |  #1
...And are you happy with it? Ever since I put a grip on my 60D, I've found my Crumpler Industry Disgrace strap is always in the way while shooting. If I attach it to the standard mounting points on the 60D, it blocks the controls/viewfinder when I switch to portrait. If I have it on the right side mount and the attachment point on the grip, it doesn't work very well in landscape. So what's the best alternative? A hand strap? Black Rapid-style?
Zenfolio (external link)
Gear: Canon 60D / Canon G12 / Tamron 17-50 f/2.8 / Canon 35mm f/2 IS / Canon 85mm f/1.8 / Tamron SP 70-300mm f/4-5.6 / Speedlite 430 EXII / Slik 700DX legs / Cullmann MB6 head
brucea
Joined Oct 2004
May 13, 2014 12:37 |  #2
Hand strap. I hand carry the camera when out shooting and can remove the Domke strap not needed.
iazybandit
Joined Apr 2011
May 13, 2014 13:07 |  #3
I'm using it with Custom SLR Hand Strap. I also have used it with Custom Air Strap, Carry Speed, Luma Labs Cinch to name a few. When using a camera strap, I have the Custom SLR M-Plate to offset the mounting point so it doesn't get in the way when in portrait mode.
Canon :: 5D Mark IV | EOS M5
Glass/Gear :: Canon 24-70L II | Canon 50mm f/1.8 STM | EF-M 22mm | EF-M 11-22mm
FULL GEAR LIST | FEEDBACK
FS: Moza Air Gimbal with Thumb Controller and Moza AirCross Gimbal | Custom SLR Dual Glide Strap, BounceLite Flash Modifier, Tolifo LED Light, Varavon Monopod
jlt23
May 13, 2014 16:12 |  #4
I'm using a Luma Labs Cinch. It works great. I just got a RRS clamp for quick release with the Cinch. Seems to work nicely.
James
Agged
May 18, 2014 23:12 as a reply to  @ jlt23's post |  #5
Hand strap. Makes for a nice, balanced carry. :)
Feedback: https://photography-on-the.net …rch.php?searchi​d=27565292
Lowner
"I'm the original idiot"
May 19, 2014 03:32 |  #6
I use the bog-standard strap and have no problem with it at all. Its no more in the way than without the battery grip.
Richard
Ynot
Joined Jan 2012
May 19, 2014 12:14 |  #7
I'm no longer gripped, at-least for now, but if I was I'd still go with my current setup. I sold my Herringbone and made my own out of paracord. Along with that I have a Black Rapid RS-7 w/underarm stabilizer, so now when I'm in the field I have a choice. Very comfortable setup.
Tony
Governments don't live together, people live together...Ӕ
Outlaw Josey Wales
pfjbaldwin
May 19, 2014 20:24 as a reply to  @ Ynot's post |  #8
Wasn't that paracord uncomfortable on the back of your hand? No padding.
pfjohnsonphotography.c​om, pfjphoto.com, Baldwin, MD
CPS
rdwalton
May 19, 2014 20:34 as a reply to  @ pfjbaldwin's post |  #9
I use a Joby hand strap - very comfortable and works with my Arca swiss plate.
Reginald D. Walton | GEAR | Smugmugexternal link
Ynot
Joined Jan 2012
May 19, 2014 20:38 |  #10
"Wasn't that paracord uncomfortable on the back of your hand? No padding."
Not at all, I've gotten used to it. I could always slip some sort of pad onto it if I had to, but I like it as-is. My biggest complaint obout my former hand-strap was that it never accomidated my large hands well. My hand always felt trapped and that made it hard and slow to change settings. In a sense it was too wide. If I loosened the strap, it was too loose and I felt like I'd drop my camera. My paracord strap doesn't do this at all. This along with my RS-7 make a perfect combo, so I can switch whenever I want to between hand-strap and RS-7.
Tony
Outlaw Josey Wales
2,437 views & 0 likes for this thread
Latest registered member is Mortspanx
852 guests, 347 members online
