hi this shot i shot last year i hope i get some feedback best regard for all
IMAGE LINK: https://flic.kr/p/njUhjc
rebeen Member 217 posts Likes: 3 Joined Nov 2007 Location: AUS More info | May 14, 2014 06:52 | #1 hi this shot i shot last year i hope i get some feedback best regard for all IMAGE LINK: https://flic.kr/p/njUhjc Canon EOS 6D,Canon EOS 5D mark II,Canon EOS 40D, lens: canon 70-200 f2.8L ,canon 40mm F1.8 ,canon 50mm f1.8,Tamron 90mm macro f2.8 /Tokina 12-24mm f4,Sigma 24 F1.8 DG,Canon 17-40 f4L,Canon 35-70 f4
Pekka El General Moderator More info | May 14, 2014 07:41 | #2 Really nice. The second one might benefit from 1/3 from the bottom being cropped out. The Forum Boss, El General Moderator
May 14, 2014 08:05 | #3 THANKS PEKKA YES YOU ARE RIGHT THE SECOND IT WAS CROPPED, Canon EOS 6D,Canon EOS 5D mark II,Canon EOS 40D, lens: canon 70-200 f2.8L ,canon 40mm F1.8 ,canon 50mm f1.8,Tamron 90mm macro f2.8 /Tokina 12-24mm f4,Sigma 24 F1.8 DG,Canon 17-40 f4L,Canon 35-70 f4
May 14, 2014 11:39 | #4 rebeen wrote in post #16903555 THANKS PEKKA YES YOU ARE RIGHT THE SECOND IT WAS CROPPED, I think he meant that you should remove some more from the bottom. The horizon goes through the center of the pic. It would look better at 1/3 from the bottom. Although the first one is centered, it works because the reflection makes it symmetrical. Ed
May 15, 2014 05:18 | #5 my mastik i will try that Canon EOS 6D,Canon EOS 5D mark II,Canon EOS 40D, lens: canon 70-200 f2.8L ,canon 40mm F1.8 ,canon 50mm f1.8,Tamron 90mm macro f2.8 /Tokina 12-24mm f4,Sigma 24 F1.8 DG,Canon 17-40 f4L,Canon 35-70 f4
zantop Member 126 posts Likes: 24 Joined Nov 2013 Location: Florida More info | May 15, 2014 13:15 | #6 I like the first one a lot! The second one has a few things I'd make suggestions about; I would also make a tighter crop as Pekka suggests. There are also some dust spots in the sky which are very easy to take out with the healing brush or clone stamp tool. It looks like it was taken at a high ISO and then lightened up in the foreground —*in PS or Lightroom I would reduce the color noise and also probably would slide the clarity slider a bit back. NickZantop.com - my portfolio
| Latest registered member is griggt 1417 guests, 109 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
