From the folks who brought you Raw Digger:
http://www.fastrawviewer.com![]()
in Beta now.
kirk
kirkt Cream of the Crop More info | May 14, 2014 12:23 | #1 From the folks who brought you Raw Digger: Kirk
yendikeno Senior Member More info | May 15, 2014 18:52 | #2 Thanks, hadn't heard of this before. _____________
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | May 27, 2014 06:23 | #3 Marvelous app! This has become the first station on my workflow. A few bugs still, for instance the XMP sets LR's Process Version to 2010 and overrides my custom defaults, but I wrote a preset that puts everything back to my defaults except the Basic panel, so the WF is now 1. Fast Raw Viewer and set exposure according to Raw histogram, 2. open in LR, 3. "Read metadata from file", 4. Apply preset. Elie / אלי
May 27, 2014 08:16 | #4 Email Iliah and let him know of the bug - it's beta. Kirk
PixelMagic Cream of the Crop 5,546 posts Likes: 6 Joined Nov 2007 Location: Racine, WI More info | May 27, 2014 08:24 | #5 I've been testing it myself; so far so good. The UI could use some work to bring it up to modern standards and unfortunately it doesn't have genuine full screen mode. The bright border near the menu bar when in full screen is rather distracting.
tonylong ...winded More info | May 27, 2014 12:44 | #6 So, I haven't downloaded it -- Elie, let me get this straight -- if you open a Raw file it automatically sets it to PV 2010? Does this mean that if I open a folder/file that I've already processed in PV 2010 that it will revert in the xmp file to 2010? Tony
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | May 27, 2014 17:25 | #7 tonylong wrote in post #16933718 So, I haven't downloaded it -- Elie, let me get this straight -- if you open a Raw file it automatically sets it to PV 2010? Does this mean that if I open a folder/file that I've already processed in PV 2010 that it will revert in the xmp file to 2010? If so I hope they get it fixed in case one wanted to look at old shoots! You can turn off XMP creation if you merely want to use it as a fast loading browser with a Raw histogram, over/under exposure colored overlays and numerical readout in number of pixels and percentage of total, focus peaking and a few other features; but if you want to use either the auto or manual exposure correction or the Adobe style ranking tags and then to transfer that metadata to LR/ACR, it has to be done with an XMP (even the great Iliah Borg can't insert metadata into a CR2) and at the moment that FRV-created XMP seems to contain a line that sets P. V. 2010. It should be noted that LR does not automatically read and load data from an XMP, it has to be given a menu command. In ACR the action is automatic, however. Elie / אלי
May 27, 2014 17:30 | #8 Yes, exposure in FRV is scaling of the linear raw file. This would not be compatible with PV2012, which does things "automagically" but not uniformly, physically or predictably. But it looks "good!" Kirk
tonylong ...winded More info | May 27, 2014 17:44 | #9 Well, it sounds interesting, then a question would be: if you want to "see" adjustments that you've made in LR in FRV, do you convert to PV 2010, Save Metadata to xmp, and will PVR "see" the adjustments? Tony
May 27, 2014 20:23 | #10 I would think that FRV is really for a first (or zeroth) step in raw processing. I see it as a way to evaluate your images for exposure and focus, with access to the actual raw histogram and focus peaking feedback. This is especially useful for ETTR. You can cull and rate the images, and sort them into separate folders from within FRV. FRV is not an editing or conversion tool but an evaluation tool, free of the auto adjustments or rendering lag of the typical raw converter. If you want to pass the exposure adjustment to LR/ACR, then you have to do it in a uniform, deliberate way - that takes the new PV2012 auto-ranging highlight compression out of consideration. If ACR/LR were to actually give the user the ability to control the highlight compression and exposure, then it would be a no brainer. Interaction with Adobe Programs Exposure adjustment is recorded in XMP-file in the FastRawViewer format (if reading/recording XMP is on). Moreover, exposure adjustment in a format that is compatible with Adobe (Bridge, Camera Raw, Lightroom) is recorded in XMP as well. This recording can be turned off through Preferences – XMP – Read/Save Adobe style exposure adjustments from/to XMP. Sadly, Adobe programs also use hidden exposure adjustments. Those are: Different for different cameras Different for different ISO settings even for the same camera Different for different “versions of the process”. To achieve best compatibility of exposure adjustments in FRV with Adobe, it is necessary to find the value for that additional (hidden) exposure adjustment that you need and set it in Preferences–XMP–Adobe-FRV exposure difference. The standard adjustment value (1.0EV) works well with many Canon cameras for ISO settings in the range of the “base ISO” to 6400. For other cameras, you may need to experiment with this value. kirk Kirk
tonylong ...winded More info | May 28, 2014 01:43 | #11 Well, hey, I downloaded/installed FRV, WhooHoo! Tony
tonylong ...winded More info | May 28, 2014 01:45 | #12 Oh, and I was also happy to see that my LR conversions came out very good in comparison! In fact, one thing I believe adds a lot in LR is the Clarity control! Tony
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | May 28, 2014 02:43 | #13 tonylong wrote in post #16934406 Well, it sounds interesting, then a question would be: if you want to "see" adjustments that you've made in LR in FRV, do you convert to PV 2010, Save Metadata to xmp, and will PVR "see" the adjustments? No, FVR does not read and apply an XMP, it is "write only". There is a saying, "Anyone could have discovered what Einstein discovered, but he would have had to be an Einstein to do it." To do LR developing the app would have to be LR, or ACR which is the same. A question: I've seen mention of FRV showing "noise" -- is this just noise without noise reduction (as in not doing the default LR Color noise reduction, so it shows up say zooming to 100%? I'm asking because I had been under the impression that there was some kind of noise "indicator" (like it has for contrast "Edges" and fine Detail, but seemingly not! Yes, that's right. As well as doing a preliminary exposure adjustment (referred to in FRV's site and quoted by Kirk) LR also does under-the-hood sharpening and NR (all these are fixed according to camera model and done before the additional measures dialed in by the user), but in FRV the histogram refers to the raw Raw. Don't forget, however, that the image you see is a fast conversion which has been WBed and had its gamma corrected with the sRGB tone curve and the shadows boosted (unless you turn it off). It will also contain features imparted to it by the conversion engine (probably Dave Coffin's DCRaw) so I wouldn't read too much into a visual inspection. To achieve best compatibility of exposure adjustments in FRV with Adobe, it is necessary to find the value for that additional (hidden) exposure adjustment that you need and set it in Preferences–XMP–Adobe-FRV exposure difference. The standard adjustment value (1.0EV) works well with many Canon cameras for ISO settings in the range of the “base ISO” to 6400. For other cameras, you may need to experiment with this value. Kirk, to see the "hidden" adjustments made by Adobe, which are specific to the camera model, you can convert a CR2 to DNG and they are then recorded in the Exif (see below). Although I don't know what the noise and sharpness units are, I have read that the exposure bias is in EV and will therefore make a more accurate setting than the generic 1.0 EV. Image hosted by forum (686359) © tzalman [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Elie / אלי
IliahBorg Mostly Lurking 11 posts Joined May 2014 More info | May 28, 2014 08:06 | #14 Gentlemen, thank you for your interest.
tonylong ...winded More info | May 28, 2014 10:53 | #15 Thanks, Iliah! Tony
| Latest registered member is semonsters 1454 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
