The question would be as to whether the OP has the original shot/image (in the full resolution) or only has the one resized to 1500 pixels!
detox wrote in post #16909217
Thanks all, yes I have the original but I was trying to save time. I process & re-size for web and then post on forums etc. However recently I've been asked for high rez copies and to make life easier thought / hoped I could just take the processed image and up the resolution. So it looks like I'll have to dig out the origonal and start from scratch
The images are at 72 and I'm being told they need to be 150 or higher for print in programs etc.
Thanks again.
detox
The "72 ppi" figure is only an image "tag" that was assigned when you resized/exported the image for the Web. It does not refer to the "actual" resolution of the image.
The advice from the printer for "at least 150 ppi" refers to the fact that for a decent print, your image should have a "working/actual resolution" of at least 150 ppi. This may or may not be reflected in the "tag", but just realize that if you want, say, a 4x6 print at a resolution of 150 ppi, the actual image size in pixels would need to be 600x900 pixels, which would certainly "fit" your 1500 pixel Web image, but if you needed, say, an 8x12 print @ 150 ppi, then your image size/resolution would need to be at least 1200x1800 pixels. And you should know that the "150 ppi" figure is pretty much the minimum as to what is considered a usable print resolution unless you are making prints meant to be viewed at a considerable distance.
As I said, that 72 ppi "tag" really doesn't mean anything unless you are preparing an image to print using a process that "pays attention" to those tags. But for some print providers they may want to "see" the tag, in which case you can deliver an image with a tag that actually expresses the desired print size in inches at a "working" ppi resolution, so you could provide a 1200x1800 pixel image with a "tag" of 150 ppi designed for an 8x12 print at a "medium" print quality...
