I'm in the market for a new tripod and need some help. I mainly shoot landscape and macro. On some days I could walk 6 hours, others just 2. I may be standing in moving water or the hot desert.
As far a weight, I'm coming from an older aluminum Bogen/Manfrotto 3020 tripod that weighs 5 lbs (2kg) without the head. I can't find the exact spec's online, but I've read others saying that it's rated to handle about 13lbs. This must be long before ratings were changed to a gimic as this has been rock solid with anything I've put on it with almost no flex even splayed completely out. There are lots of things I don't like and why I'm shopping around.
After hunting for about two weeks I've settled on Feisol. I like the build quality from what I've read, the warranty, the compactness, weight and ease of use. I'd also like to stay around the $400 range. The thing is, I'm not convinced of the rigidity. I've watched videos on the 3441T/3442 and compared to my Bogen they seem flimsy and shaky even rated at 22lbs. Am I wrong here?
I'd prefer a flat spider/no center column, but if the CC's rock solid set all the way down I may be persuaded and at that point and then purchase a short CC replacement.
The reason for the 3441T consideration is that I have some back issues and would prefer not to hunch all the time and at-least have a choice. I only stand 5'9", but I have to add this into the equation. The consideration on the 3442 was based on the wide flat spider that would allow the head to be inverted into the legs and the compactness overall.
I'd also like it to be CF, easily attach it to a backpack, have fast twist locks, and head to fit into inverted legs, but isn't absolutely necessary. As far as warranty in the $400 range, I don't expect much, 3 years seems about average. Good customer service that listens and quickly addresses an issue is also important.
Recommendations? Step up to the 337x line? Other?
