Thread started 13 Feb 2006 (Monday) 08:12
G5 image problem.
slim ­ uk
Joined Feb 2006
Feb 13, 2006 08:12 |  #1
hello folks,help neede if possible.i have a g5 and i am very pleased with the quality of my pics,apart from any that have a lot of sky in them. they seem to have a very faint line running from top left to half way down the right side of the image.this faint line is visible on the lcd and print. any help or suggestions would be great. Slim.
G5,+RAYNOX O.66X,+RAYNOX 1.85X =NICE MIND:cool:
photodd
Feb 13, 2006 09:53 |  #2
Post a shot so we can see what exactly it is.
http://www.jaytoddphot​ography.com (external link)
slim ­ uk
Joined Feb 2006
Feb 13, 2006 14:22 |  #3
not much but very annoying:(
slim ­ uk
Joined Feb 2006
Feb 13, 2006 14:52 |  #4
Nobody seems to notice this mark but i see it on every picture.
photodd
Feb 13, 2006 15:42 |  #5
Kind of your own watermark...
Seriously though, if this were in the same place on every shot, I would be upset. Does it show up only when using the Raynox adapters?
Terrywoodenpic
Feb 13, 2006 16:02 |  #6
is this in the exact same position no matter what zoom setting is used .
Or does it cange size and position with the zoom change.
If it is always the same no matter what it is a sensor problem for sure.
Otherwise we shall need to see more pictures at other zoom settings.
If it is a sensor problem you will have to send it back to canon, complete with pictures.
It is probably the best option anyway.
Terry_______________
Over 60 years in photography
wasted money cameras never on film.
slim ­ uk
Joined Feb 2006
Feb 14, 2006 03:18 |  #7
the mark is in the same place each time i use the cameras own wide angle.it is not there when i zoom, so this makes me think it could be a hair in between the lens.not noticable at all when i use the raynox lenses.
superkully
Feb 14, 2006 04:59 as a reply to  @ slim uk's post |  #8
I didn't notice it until I read your description. But now I know about it, I can't help being drawn to it.
Are there any marks on the lens at all? It could be some (very fine, very straight) dust on the inside...
slim ­ uk
Joined Feb 2006
Feb 14, 2006 05:10 |  #9
not that i can see.it is not visable at all when i have a dull background but to me it sticks out like a sore thumb if i have a light background.
Robert_Lay
Feb 14, 2006 13:42 as a reply to  @ slim uk's post |  #10
I have no problem at all in seeing it, but had you not given good directions, I could have just as easily never noticed it.
Once you have determined that it is a problem in the sensor, you should immediately send it away for repair.
Here is the best way to test the camera. Go into a very dark room and take a picture with manual settings, wide open aperture and about 2 seconds, while holding the lens cap over the end of the lens (or use anything that you can find that makes a good light-tight seal with the end of the lens - such as burying it under a pillow).
When you look at that image in an imaging program and when you post it here, we can all verify the problem.
Just to be on the safe side, take a similar picture of an all white wall, brightly lit, and and this time use Av mode, wide open lens and +1 1/3 Exposure Compensation.
Bob
Quality of Light (external link), Photo Tool ver 2.0 (external link)
Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration.
slim ­ uk
Joined Feb 2006
Feb 15, 2006 10:11 |  #11
cheers Bob, i'll try this as soon as i get a chance.i've just moved house so things are pretty hectic at the moment,but i will post the results asap.thanks again Simon.
1,689 views & 0 likes for this thread, 5 members have posted to it.
G5 image problem.
2144 guests, 127 members online
