Thread started 21 May 2014 (Wednesday) 19:24
DOF in bird photography-
ardeekay
Gallery: 69 photos
May 21, 2014 19:24 |  #1
Been batting this around a bit in the photo-sharing section-thought I'd post here to see if I could get another perspective or more insight.
A very accomplished member recently posted a series of very sharp Hummingbird photos. Turns out his exif was +/- 500-550 mm focal, f/8 aperature and 9-9.5 feet distance to subject. Body was MarkIII. My DOFMaster dof calculator indicates dof is around .04-.05 feet or about 1/2 inch. Yet the entire bird is in sharp focus. I have been struggling w/ issues that I thought were related here, but now I'm slightly confused. Any thoughts??
Thank you.
Rog
Foggiest
Joined Mar 2012
May 22, 2014 05:38 |  #2
Could you link to the pictures?
ardeekay
Gallery: 69 photos
May 22, 2014 06:06 |  #3
Foggiest wrote in post #16921896 (external link)
Don't think that would add any meaningful info. plus they're not my pix. The owner of these images suggested that while 1/2" might be the "tack-sharp" dof, there is a +/- area of "acceptable" sharpness and that is what I saw there. I was just looking for other thoughts/opinions re:dof that tight even at a relatively small f-stop. Thank you.
Rog
hollis_f
May 22, 2014 06:17 |  #4
Your DoFMaster program will be working on several assumptions. One of these is that the image will be printed at 10x8 and viewed from one foot. If you're looking at an image on a web page then it's likely to be smaller than 10x8 and you're likely to be viewing it from more than 1 foot away. Both of those will increase the DoF.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
ETS
Gallery: 31 photos
May 22, 2014 06:53 as a reply to  @ hollis_f's post |  #5
Another thing you have to consider is the angle the bird is relative to the plane of focus. I looked at the photos the OP is referring to and for the most part the hummers are pretty much parallel to the plane. That plus the small size of the birds accounts for the fact that most of them are in sharp focus.
Fuji X-T2,5D MKII,Rebel XTi
17-40L, 70-200 F4L, 400mm F5.6L, 100mm F2.8L, Sigma 35mm f1.4 Art
580 EX II
ardeekay
Gallery: 69 photos
May 22, 2014 08:08 |  #6
hollis_f wrote in post #16921922 (external link)
OK-the scientific principles involved here pretty much escape my pea brain, but I guess it relates somewhat back to that "acceptable" sharpness that the photographer mentioned. Thank you.
Rog
ardeekay
Gallery: 69 photos
May 22, 2014 08:13 |  #7
ETS wrote in post #16921963 (external link)
These principles I can understand. And it means I have other issues besides dof w/ my hummer shots-mostly low light and slow ss. Thanks for responding.
Rog
Foggiest
Joined Mar 2012
May 22, 2014 09:56 |  #8
Isn't DOF kinda of a term of convenience?
I mean there is only a single narrow plane that is in focus, the rest gradually falls off.
So the term of conveyance is one of human understanding/explaini​ng rather than absolute.
Kinda like the +- charge of electron :p
Archibald
You must be quackers!
Gallery: 789 photos
May 22, 2014 10:15 |  #9
Small birds require a smaller aperture, and big birds can do with a bigger aperture.
To get an idea of the f stop required in different situations, one can make some assumptions, as follows.
- The bird being photographed mostly fills the frame
- The required DOF is 1/4 of the width of the field of view at the subject
- APS-C format
Then one needs to use the following f stop or smaller. This works for all focal lengths and shooting distances (those variables cancel out of the calculations).
- Goose f2.8
- Duck f4
- Crow f5.6
- Robin f8
- Sparrow f11
- Hummingbird f16
This is obviously a bit silly, because situations and requirements vary. But it shows a trend that is valid. Adapt as necessary.
I'm Ed. Migrating to Focus on Photography (https://focusonphotogr​aphy.community.forum/ (external link)) where I'm Archibald.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
May 22, 2014 10:35 |  #10
ardeekay wrote in post #16921057 (external link)
... Body was MarkIII. ..
which one? 10.5MP 1.3x, or one of the two 22 MP Full Frames?
Just curious.
CDS' HOT LINKS
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
May 22, 2014 10:39 |  #11
Foggiest wrote in post #16922252 (external link)
Try to measure that depth of "gradual fall off" when your aperture, focus and focal length offer a hyper focal solution.
I suppose in a metaphysical realm, there might be a measurable fall off, (actually I don;t know if this IS how it works) but for all intents and purposes, everything is in focus, not one sliver a plane.
CDS' HOT LINKS
Foggiest
Joined Mar 2012
May 22, 2014 10:49 |  #12
CyberDyneSystems wrote in post #16922331 (external link)
Not being cheeky here Jake, but I can't see it that way myself(in minds eye etc).
I see it as a human perception thing.
Even our level of equipment seems to detect differences within the DOF...
I think that it helps to understand DOF better to realise that it is not a set of depths like a ruler, but more a set of curves.
Makes more sense that way to me.
To paraphrase Hollis "Depends how close you want to look at it?" ;)
hollis_f
May 22, 2014 13:17 |  #13
Hmmmm, one common problem when people start doing wide-angle astrophotography is that they believe that they don't need to worry too much about getting the focus right because of the huge depth of field. One soon learns that, even at 10mm, getting the focus spot-on is very important.
If you focus at the hyperfocal distance then anything at infinity (like stars) will be right at the very edge of the 'acceptable' range of focus. But what is acceptable when shooting landscapes is far from acceptable when shooting starscapes. Using 10x with liveview and manual focus you really can see how the focus does 'fall off' as one moves away from true infinity.
ardeekay
Gallery: 69 photos
May 24, 2014 11:38 |  #14
CyberDyneSystems wrote in post #16922329 (external link)
Just curious.
I checked closer-actually was a 5D MarkII.
Rog
ardeekay
Gallery: 69 photos
May 24, 2014 12:08 |  #15
Archibald-I think you just twisted my brain into a knot:) The largest bird-the largest aperature which yields the narrowest dof and the smallest bird the smallest fstop w/ the greatest dof? Seems like it should be the opposite. Looking at the 1/4 field of view for the req'd. dof thought-say you have an 8" field of view for a hummer equals 2" dof and likewise, you might have a 48" field giving a 12" dof. While this seems right to me, I'm missing how f16 and f2.8 give those dof's respectively. What am I missing:confused:
Foggiest, Jake, Frank-I'm going to have to ponder your thoughts-getting pretty technical for me.(See paragraph 1::o)
Rog
5,822 views & 0 likes for this thread, 9 members have posted to it.
2786 guests, 135 members online
