NewCreation wrote in post #16924811
Thanks. He seems to be a common recommendation.
As in it's just firing the flash no ttl, correct? Just want to be sure I am understanding.
So are you saying that I can't do hss with just the trigger and my 568ii? I found I can trigger the 560iii with a 603 mounted in my 622c in the hotshoe and trigger the 568ii with my second 622c but the flash changes to manual. Is that what you meant?
I thought I was figuring this out but am still a bit confused.
Full TTL, just a group A flash. It will fire in standard TTL, but if you set the 622 to fire groups (ratio, manual, etc) it will be in group A.
Do not confuse HSS (strobing flashes repeatedly to cover the Chip) with Hypersync (long burn single flash that is long enough duration to become effectively a 'continuous light source'). Do a search on it, many have explained it better than I can.
The flash changes to manual? It shouldn't, it should remain in whatever mode the on-camera 622 is telling it to be in, as its being controlled by the on-camera 622. Try doing a full reset of the 622 and trying again.
