Thread started 24 May 2014 (Saturday) 00:04
Couple of Newborn Photos.
Sere81
May 24, 2014 00:04 |  #1
I'm literally lost with my technique it seems. I can snap 50 pics and only 5 or so will be in focus. The rest will be so soft they are unusable. And I really have no idea what I'm doing wrong to correct it cause it doesn't feel like I'm doing anything different when the photos turn out sharper. On to the pictures as promised.
IMAGE: https://farm3.staticflickr.com/2912/14069234869_5cfd6d9569_c.jpg
IMAGE: https://farm3.staticflickr.com/2932/14252583051_9e6b38bf58_c.jpg
Thanks for looking.. Like I said, these and a couple more are the only useable shots from each session. The rest are garbage.
Website (external link) | Flickr (external link)
Titus213
May 24, 2014 00:53 |  #2
#2 looks pretty good. #1 looks hot and that arm in the foreground is a bit in your face.
Do you have the exif on these? Out of focus can be caused by many things but in my experience seldom hardware.
Use a single point AF which YOU select - don't let the camera do it for you.
Dave
Perspiring photographer.
Sere81
May 24, 2014 08:05 |  #3
Both are using Tamron 17-50mm and both are using center focus point only. I do use a focus and recompose method a lot and wondering if that could be it.
First Pic
Make Canon
Model Canon EOS DIGITAL REBEL XTi
exposureTime 1/60
FNumber 2.8
ExposureProgram Manual
ISO 400
ExifVersion 0230
DateTimeOriginal 2014:​04:01 17:29:16
CreateDate 2014:04:01 17:29:16
ShutterSpeedValue 1/60
ApertureValue 2.8
ExposureCompensation 0
MaxApertureValue 2.8
MeteringMode Partial
Flash On, Fired
FocalLength 42.0 mm
ColorSpace sRGB
FocalPlaneXResolution ​4433.295325
FocalPlaneYResolution ​4453.608247
FocalPlaneResolutionUn​it inches
CustomRendered Normal
ExposureMode Manual
WhiteBalance Auto
Second
Make Canon
XResolution 240
YResolution 240
ResolutionUnit inches
Software Adobe Photoshop Lightroom 5.4 (Macintosh)
ModifyDate 2014:05:24 00:54:13
ExposureTime 1/40
FNumber 2.8
ExposureProgram Apertu​re-priority AE
ISO 800
ExifVersion 0230
DateTimeOriginal 2014:​05:15 19:04:06
CreateDate 2014:05:15 19:04:06
ShutterSpeedValue 1/40
ApertureValue 2.8
Flash On, Fired
FocalLength 42.0 mm
ColorSpace sRGB
ExposureMode Auto
WhiteBalance Auto
rrblint
Gallery: 84 photos
Joined May 2012
May 24, 2014 08:14 |  #4
Nice photos here.:)
Your shutter speed is a bit on the slow side, could be camera shake causing your problems. Also focus/recompose can cause focusing problems with the lens wide open but usually only at f2 or wider.
Mark
Titus213
May 24, 2014 10:43 |  #5
You are close up to the subject and using wide apertures so focus and recompose could be an issue. Manually select the AF point nearest to the eyes in these cases.
Shutter speed is marginal/minimum recommended. Rule of thumb is 1/focal length. Flash should help that a bit but onboard flash will generally not be real flattering. Flash and any mode other than manual on the camera could also be an issue.
Dave
vk2gwk
Gallery: 332 photos
May 24, 2014 20:38 |  #6
Shooting @ 42mm with a crop sensor with an aperture of F/2.8 at a distance of less than 1 M from your subject gives you a depth of field (DOF) of between 3 and 6 cm. So focussing and recomposing easily takes the eyes away from the focal plane.
Shooting with an on camera flash pointing at babies is something I would not like to do - very uncomfortable for the kiddies that are prone to get scared.
Get the flash of camera with a diffuser or reflector.
Get a dedicated backdrop so you don't need to rely on wide aperture to get rid of background distractions.
And keep practicing... :)
My name is Henk. and I believe "It is all in the eye of the beholder....."
Image Editing is allowed. Please explain what you did!
Canon R5, R,, RF24-105/1:4 + RF70-200mm F/2.8 + RF15-35mm F/2.8 + 50mm 1.4 USM + Sigma 150-600mm Sports + RF100mm F/2.8 + GODOX V860 IIC+ 430EX + YN568EXII, triggers, reflectors, umbrellas and some more bits and pieces...
Photos on: Flickr! (external link) and on my own web site. (external link)
Sere81
May 24, 2014 22:38 |  #7
Thanks all for the kind words and advice.
1,417 views & 0 likes for this thread, 4 members have posted to it.
963 guests, 182 members online
