Check this out...
Shipwrecked camera found underwater after 2 years with photos intact![]()
RTPVid Goldmember 3,365 posts Likes: 3 Joined Aug 2010 Location: MN More info | May 24, 2014 10:04 | #1 Check this out... Tom
Luckless Goldmember 3,064 posts Likes: 189 Joined Mar 2012 Location: PEI, Canada More info | May 24, 2014 10:21 | #2 My main complaint about SD cards isn't whether or not they're fragile, but the size and slow speed potential. I would have much preferred if something closer to CF had stayed the mainstream. (And those micro cards are just evil... That much data should not be stored on something small enough to easily lose in short grass or be blown around by a stiff breeze.) Canon EOS 7D | EF 28 f/1.8 | EF 85 f/1.8 | EF 70-200 f/4L | EF-S 17-55 | Sigma 150-500
CameraMan Cream of the Crop More info | May 24, 2014 10:24 | #3 I was testing a dashboard cam in my car a few weeks ago and went to take out the brand new SD card I bought for it and the thing shot out and I think it fell in the shifter housing. I can't find that little 32GB POS anywhere... Photographer
CRCchemist Senior Member 961 posts Likes: 19 Joined Apr 2014 More info | May 24, 2014 17:42 | #4 CameraMan wrote in post #16926912 I was testing a dashboard cam in my car a few weeks ago and went to take out the brand new SD card I bought for it and the thing shot out and I think it fell in the shifter housing. I can't find that little 32GB POS anywhere... Same thing happened to me. I used a vacuum cleaner to extract it from the crevice. Worked like a charm.
CameraMan Cream of the Crop More info | May 24, 2014 18:11 | #5 I'll have to try that. Photographer
rcdude Junior Member 20 posts Joined Jun 2013 More info | May 25, 2014 12:35 | #6 CameraMan wrote in post #16927671 I'll have to try that. Put a pair of nylons over the end of the vacuum so it won't get sucked up all the way. It will just be sucked up against the nylons. Hope this tip helps
CRCchemist Senior Member 961 posts Likes: 19 Joined Apr 2014 More info | May 25, 2014 13:18 | #7 rc dude wrote in post #16929223 Put a pair of nylons over the end of the vacuum so it won't get sucked up all the way. It will just be sucked up against the nylons. Hope this tip helps Haha I just used a clean vacuum cleaner and pulled it out of the collector.
madjack Goldmember More info | I'm kind of ham fisted, so SD cards would be easy for me to drop or lose. Canon 5D Mk IV | Canon 5D Mk II | Canon 7D | Canon 30D
Diamond-Lord Junior Member 29 posts Joined May 2014 More info | May 25, 2014 20:51 | #10 CameraMan wrote in post #16926912 I was testing a dashboard cam in my car a few weeks ago and went to take out the brand new SD card I bought for it and the thing shot out and I think it fell in the shifter housing. I can't find that little 32GB POS anywhere... Why don't you just live-stream the dashcam video directly to the cloud instead of taking a chance on losing SD cards?
Ontheloose Junior Member 21 posts Joined Jan 2014 More info | I dropped a cheap one onto the road, it fell apart. Luckly I was putting an empty card into the camera.
CameraMan Cream of the Crop More info | May 28, 2014 19:44 | #12 Diamond-Lord wrote in post #16930051 Why don't you just live-stream the dashcam video directly to the cloud instead of taking a chance on losing SD cards? :p Camera doesn't have internet connection nor wireless capabilities... Photographer
May 28, 2014 19:59 | #13 and damn that would be some expensive internet. Stuff
Diamond-Lord Junior Member 29 posts Joined May 2014 More info | May 28, 2014 22:05 | #14 peeaanuut wrote in post #16937032 and damn that would be some expensive internet.
eelnoraa Goldmember 1,798 posts Likes: 37 Joined May 2007 More info | May 29, 2014 13:28 | #15 Modern SD and uSD card is made in the form of SIP package, meaning the entire card is a molded from filberglass/plastic substrate with all memory, controller and PCS within. None of the actual electrical components are exposed to the element except the contact pins. That is why flesh water and mud are not issue. Salt water wills till corrode the contact pins tho. 5Di, 5Diii, 28, 50, 85, 16-35II, 24-105, 70-200F2.8 IS
| Latest registered member is semonsters 1380 guests, 135 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
