Thread started 28 May 2014 (Wednesday) 17:41
Help with Rokinon 8mm F3.5 Fisheye
Chopper ­ Al
May 28, 2014 17:41 |  #1
Hey folks,
Just picked up a used Rokinon 8mm F3.5-22 fisheye lens. I know it is all manual and have the process of obtaining fairly good exposures without too much problem.
Where I am having problems is trying to nail the focus. So far, I have been able to get 1-2 half decently sharp images. The others seem to be out of focus in pretty much the whole image. I am using a shutter speed of between 1/125 and 1/500, so I don't think motion blur would be an issue.
The image of the bush is one that seems relatively sharp and the image of the backyard is out of focus all over.
Backyard:
ISO 100
F/5.6
Shutter 1/60
Bush:
ISO 100
F/5.6
Shutter 1/60
Any help or ideas would be greatly appreciated.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/05/4/LQ_686443.jpg
Image hosted by forum (686443) © Chopper Al [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/05/4/LQ_686444.jpg
Image hosted by forum (686444) © Chopper Al [SHARE LINK]
RodneyCyr
Gallery: 31 photos
May 28, 2014 18:36 |  #2
Could there be something wrong with your lens? I suggest re-taking both test shots using various settings on the focus scale. See what happens. Is the focussing scale accurate?
I recently bought the same lens and am quite satisfied with it. But I have had several problems. First, I find it impossible to focus through the viewfinder of my 70D, even when I use live view and 10x magnification. This might be because the lens is soft at f3.5 and the depth of field is so great that everything is in focus anyway. I normally use it at f/5.6 indoors and f/11 outdoors. I focus manually using the distance scale.
Second, when using the Av exposure mode, I get good exposures indoors, but grossly overexposed shots outside. Outside, I resort to the manual mode and the "sunny f/16" rule, i.e. ISO 100, 1/200@f/11, etc.
In the POTN forums is one for lens sample images. Find the Rokinon fisheye thread for samples and other comments about the lens.
Canon 80D, 60D, Canon 10-22EFs, 15-85EFS IS, Sigma 100-400, Sigma 135/1.8ART, Sigma 30mm f/1.4DC, Canon 60mm EFs Macro, Rokinon 8mm fisheye, 550EX flash, Olympus TG6 underwater P&S
Postprocessing: DxOLabs 5, DxO Viewpoint 3, Paint Shop Pro 2021
Speak softly and carry a big zoom.
EverydayGetaway
Gallery: 11 photos
Joined Oct 2012
May 28, 2014 19:21 |  #3
Use 10x magnification in LV to see if you can get anything in focus, it's not uncommon for these lenses to have their focus rings miss-aligned and it's easy to fix if that is the problem. Generally if you just focus to infinity most things will be in focus even when wide open.
Fuji X-T3 // Fuji X-Pro2 (Full Spectrum) // Fuji X-H1 // Fuji X-T1
flickr (external link) // Instagram (external link)www.LucasGPhoto.com (external link)
Chopper ­ Al
May 28, 2014 21:01 |  #4
Thanks for the info guys. I have tried going all the way to F22, but was mainly at F5.6. I tried focusing from 1 foot all the way to infinity. The backyard image was set with focus almost to infinity. I only paid $149 USD for the lens, so perhaps it is a bum lens?
EverydayGetaway
Gallery: 11 photos
Joined Oct 2012
May 28, 2014 21:48 |  #5
Chopper Al wrote in post #16937195 (external link)
Again, check the focus in LV. They're often off from the factory, all you have to do to adjust it is pull back the rubber on the focus ring and loosen a few screws, adjust the ring, tighten it back up and you're good to go.
snake0ape
May 29, 2014 00:29 |  #6
EverydayGetaway wrote in post #16937283 (external link)
Once you calibrate your distance ring. Keep it at 10ft and set at f8. Everything should be in focus with those settings.
5Diii | 50D | 8-15L 4| 16-35L 2.8 II| 24-70L 2.8 II | 70-200L 2.8 IS II |Tamy 150-600 | Σ35Art 1.4 | 40 2.8 | Σ50Art 1.4 | 85L 1.2 II | 100 2.8 Macro | Helios 44-3 58mm f2.0 |Helios 40-1 85mm f1.5 | 1.4x & 2x teleconverters
paul-t
Location: The deep south, that's the deep south of England.
May 29, 2014 11:36 |  #7
Hi there, I have the Samyang 8mm (same lens) and I never focus the lens. All I do is set the focus to just under infinity and bobs your uncle, sharp every time. Hope this helps.
2,093 views & 0 likes for this thread, 5 members have posted to it.
921 guests, 108 members online
