Thread started 29 May 2014 (Thursday) 23:58
Problems with SIgma 50mm 1.4 ART
Thestructured
Joined Jun 2012
May 29, 2014 23:58 |  #1
I want to love this lens so much because the optics are amazing. The colors are rich and the contrast is great...so is the flare control and the sharpness. But The focus inconsistency is driving me insane. Using center focus points on my 5d mark 3 it seems to be focusing well most of the time. Using outer cross type points, it's front focusing intensely. Focusing with the center point and recomposing yields an in focus photo while using an outer point falling on the focus area does not.
I have experienced this type of issue so many times, with nearly every canon camera I've ever owned, however I haven't noticed this with my 5d mark iii until I mounted this lens. I have no idea whether it's the lens or camera, but I don't recall having this issue with other lenses (except other 50mm lenses....). It's not user error, I've tested it on a tripod, and I shoot my 85L at f1.2 hand held all the time with no issues. I have no idea whether to send the camera in for calibration or the lens.
Frustration. Why can't things just work.
2x Nikon D750// nikkor 24-70 2.8g // sigma 35mm 1.4 art// sigma 50mm 1.4 art// nikkor 85mm 1.4g// Nikkor 70-200 2.8 vr ii // 4x SB700// WL x3200 + x1600 http://www.marekkphoto​graphy.com (external link)
sportmode
Joined Nov 2010
May 30, 2014 00:25 |  #2
Why not return it and get a new one?
5D Mark III, 6D, EOS-M 22mm f/2 | 24-70mm f/2.8L II | 50mm f1.4 | 100L | 70-200mm f/2.8L IS II | Rokinon 8mm Fisheye
Thestructured
Joined Jun 2012
May 30, 2014 00:33 |  #3
Because they are on pre-order, they are not in stock anywhere. Also, there is a large dust spec already inside the front element. I've had the lens for ONE DAY.
Maybe I will try to exchange it.
mystik610
Gallery: 36 photos
Joined Jan 2012
May 30, 2014 00:37 |  #4
Have you micro focus adjusted your lens? Mine needed a +5 adjustment.
focalpointsphoto.com (external link) - flickr (external link) - Instagram (external link)
α7ʀIV - α7ʀIII
Sigma 14-24 f2.8 ART - Zeiss Loxia 21 - Sigma 35 f1.2 ART - Sony 35 1.8 - Sony/Zeiss 55 1.8 - Sony 85GM
Thestructured
Joined Jun 2012
May 30, 2014 00:41 |  #5
Adding +4 MA tweaked the center point focusing to perfection, but does nothing to fix the outer points. If I MA +20, then the focus is almost right when using outer focus points, but screws up focus with the center points.
I don't know what the deal is. I will have to test it on my other camera when I get back to my house (I'm out of town). Nothing more frustrating than putting hundreds of actuations on your cameras trying to figure out an issue.
DreDaze
Gallery: 45 photos
May 30, 2014 00:54 |  #6
if focus recompose yields a in sharp photo...i'd think that would mean it's front focusing
Andre or Dre
gear list
Thestructured
Joined Jun 2012
May 30, 2014 01:02 |  #7
The center point, NOT recomposed (focusing on something in the center of the frame) results in a sharp photo. Focusing on something with an outer point, on the side of the frame, results in an out of focus photo. Turning the camera (tripod mounted) to focus on that same spot using the center focus point instead of using an outer point and turning it back to the original position, results in a photo perfectly focused where the outer point lies. Baffled.
Thestructured
Joined Jun 2012
May 30, 2014 01:03 |  #8
The full frame:
IMAGE: https://dl.dropboxusercontent.com/u/6485893/Screenshot%202014-05-30%2001.46.17.png
focused via center point and recomposed (on tripod):
IMAGE: https://dl.dropboxusercontent.com/u/6485893/Screenshot%202014-05-30%2001.46.25.png
Focused using outer point:
IMAGE: https://dl.dropboxusercontent.com/u/6485893/Screenshot%202014-05-30%2001.46.29.png
Same results in handheld tests, and I've tested multiple outer points on both sides.
rick_reno
May 30, 2014 01:07 |  #9
Given my experience with one of their 50 f/1.4 lenses, you have demonstrated why I never bought another.
Thestructured
Joined Jun 2012
May 30, 2014 01:08 |  #10
Focused straight on with a center point with no recomposition:
IMAGE: https://dl.dropboxusercontent.com/u/6485893/Screenshot%202014-05-30%2002.07.09.png
IMAGE: https://dl.dropboxusercontent.com/u/6485893/Screenshot%202014-05-30%2002.07.04.png
Thestructured
Joined Jun 2012
May 30, 2014 01:09 |  #11
rick_reno wrote in post #16939614 (external link)
yeahh.....haha
I don't have these issues with the 35mm art though.
Thestructured
Joined Jun 2012
May 30, 2014 01:36 |  #12
This article seems to hint that It may be a 5d iii issue, as a few people experience this exact problem with the 5d iii and 50L. http://www.dpreview.co​m/forums/thread/349626​4?page=1 (external link)
FEChariot
Gallery: 13 photos
Joined Sep 2011
May 30, 2014 02:04 as a reply to  @ Thestructured's post |  #13
Looks like you need to shoot in servo all the time I guess. Bryan from TDP called out AF inconsistencies in one shot too:
http://www.the-digital-picture.com …-1.4-DG-HSM-Art-Lens.aspx (external link)
I'm holding on to my Canon 50/1.4 at least until Canon releases a new 50/1.4 IS or 50/1.8 IS or what ever they come up with.
Canon 7D/350D, Σ17-50/2.8 OS, 18-55IS, 24-105/4 L IS, Σ30/1.4 EX, 50/1.8, C50/1.4, 55-250IS, 60/2.8, 70-200/4 L IS, 85/1.8, 100/2.8 IS L, 135/2 L 580EX II, 430EX II * 2, 270EX II.
youngr
Joined Apr 2014
May 30, 2014 04:22 |  #14
Is sending it to Sigma not an option?
Nick3434
Gallery: 33 photos
May 30, 2014 05:08 |  #15
Sucks. Mine is cool throughout on a 6D, maybe the thread you found is the answer.
I don't know how AF works, but I would assume the camera tells the lens to move, and if it tells it in the same language as a point that works, then wouldn't the camera be the likely culprit? I would be testing all my lenses to confirm the results, then go from there.
Everything is relative.
Gear: 6D, Unholy Trinity:twisted: (24Lii, sigma 50A, 135L), and for the other ends of the spectrum, sigmaEX 14mm2.8 and sigmaEX 100-300F4.
Fuji X-e2, Rokinon 8 2.8 Fisheye II, Fuji 14 2.8, Fuji 18-55, Fuji 23 1.4
FlikR (external link)
24,417 views & 0 likes for this thread
Latest registered member is Yahocustomer
888 guests, 260 members online
