jetcode wrote in post #16954206
Save as .jpg is size limited. I will try again. I will see if I can find the script.
Well, converting to a jpeg uses different processes, it's all up to you and how you set it up in the software. Like I said earlier, if you do want to use Image Processor for its automation, then yeah it can be nice, especially when dealing with batches of files, but if you are having issues, well, play with those IP settings, but then it's still a pretty straightforward process to open the tiff in Photoshop, do whatever processing/sharpening/color space/image size/dimensions for the print, then you can Save As a jpeg. If you set the Quality setting to a reasonably high level, you can avoid messyCompression "artifacts" (getting larger files but a better quality for a larger print).
