I purchased one of these and I must say that I don't know why we buy expensive Canon lens hoods for the non-L lenses. These are cheap, work great and they are easy to carry around on your lens in your photo-bag. Any others use them?
celter Member 99 posts Joined Jan 2006 Location: Oslo, Norway More info | Feb 14, 2006 02:22 | #1 I purchased one of these and I must say that I don't know why we buy expensive Canon lens hoods for the non-L lenses. These are cheap, work great and they are easy to carry around on your lens in your photo-bag. Any others use them? 5D Classic, 6D, 7D, Canon 16-35 f/4 L IS USM, Canon 24-105 f/4 L, Zeiss 35 f/2, Sigma 50 f/1.4 Art, Canon 100 f/2.8L Macro, Sigma APO 100-300mm f/4 EX IF HSM, Kenko 1.4X, Canon Speedlite 580EX, Canon Speedlite 90EX, Benro C-227, Benro KS-1, HP Photosmart 8750
Scottes Trigger Man - POTN Retired 12,842 posts Likes: 10 Joined Nov 2003 Location: A Little North Of Boston, MA, USA More info | Feb 14, 2006 09:04 | #2 The Canon hoods are better. You can take my 100-400 L away when you pry it from my cold, dead fingers.
jjonsalt Goldmember 1,502 posts Joined Oct 2005 Location: Central Florida More info | Permanent banFunny, some are willing to pay for a filter to 'protect' their lenses. Often for an expensive one even. But won't spring for a lens hood that will really 'protect' the lens and work/fit well (OE).
Feb 14, 2006 10:44 | #4 If you use the hood to protect your lenses I guess you're right, BUT this is not the main reason to use a hood. Anyway, use your massive Canon hoods, take them on and off every time you put the camera back in your bag/backpack. I'll be shooting with my camera before you get yours in position. 5D Classic, 6D, 7D, Canon 16-35 f/4 L IS USM, Canon 24-105 f/4 L, Zeiss 35 f/2, Sigma 50 f/1.4 Art, Canon 100 f/2.8L Macro, Sigma APO 100-300mm f/4 EX IF HSM, Kenko 1.4X, Canon Speedlite 580EX, Canon Speedlite 90EX, Benro C-227, Benro KS-1, HP Photosmart 8750
jfrancho Cream of the Crop 6,341 posts Joined Feb 2005 More info | Feb 14, 2006 10:48 | #5 The only thing that this is good for is shooting through glass. Rubber hoods are more difficult to extract from the bag because, well, they're rubber and get caught on the inside of the bag, strapr, flaps, etc.
jjonsalt Goldmember 1,502 posts Joined Oct 2005 Location: Central Florida More info | Permanent bancelter wrote: If you use the hood to protect your lenses I guess you're right, BUT this is not the main reason to use a hood. It is, however, as important a feature as blocking stray light. celter wrote: ...use your massive Canon hoods, take them on and off every time you put the camera back in your bag/backpack. This I don't really understand, above you imply that blocking stray light is THE main feature of a hood and yet you criticise an effective size. I really don't think it takes any more time to remove, reverse, and mount a large hood than a smaller one. celter wrote: I'll be shooting with my camera before you get yours in position. Maybe, but I'm not in a race with anyone. I kinda antisapate my needs and when.
bolantej Goldmember 3,780 posts Likes: 7 Joined Mar 2005 Location: CAlifornia More info | Feb 14, 2006 19:31 | #7 I had rubber pop out ones before and I did not like them. I ripped them to shreds and made them into reversing rings. but, whatever works best for you.
Streetshooter Senior Member 882 posts Likes: 2 Joined Jan 2005 Location: Phila, Pa. More info | Feb 14, 2006 19:35 | #8 Canon hoods are great cause ya can reverse them on the lens for storage.... Cheers, Don
Scottes Trigger Man - POTN Retired 12,842 posts Likes: 10 Joined Nov 2003 Location: A Little North Of Boston, MA, USA More info | celter wrote: ...BUT this is not the main reason to use a hood. Removing stray light *IS* the main reason, and a correctly-sized hood with good internal flocking is about as good as you're ever going to get. You can take my 100-400 L away when you pry it from my cold, dead fingers.
jfrancho Cream of the Crop 6,341 posts Joined Feb 2005 More info | Feb 14, 2006 19:54 | #10 Sigma 30/1.4, Sigma 50/2.8 Macro (on its way) Canon 24-105/4L, Sigma 70-300 F4-5.6 Do not all of these come with a lens hood as standard equipment? If so, just who is wasting their money?
joeseph "smells like turd" More info | Feb 14, 2006 23:13 | #11 I quite like my 24-70 hood. Can easily get the lenscap on & off with it still on, does it's job well, only thing that's a little fiddly is mounting the lens when the hood's reversed. Anyone else find this problem? some fairly old canon camera stuff, canon lenses, Manfrotto "thingy", and an M5, also an M6 that has had a 720nm filter bolted onto the sensor:
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Feb 14, 2006 23:23 | #12 The Canon EF 24-70mm f/2.8L USM lens and its matching hood (the EW-83F) is without a doubt the best engineered combination ever. The hood is quite deep and mounts to the lens BODY, not to the filter threads. The deep hood works perfectly with the lens set at 70mm - the shortest physical configuration of the lens. The lens extends when zooming towards 24mm, making the effective depth of the hood less at the wide-angle positions. Skip Douglas
blighty Senior Member 402 posts Joined Nov 2005 Location: London UK More info | Feb 15, 2006 05:40 | #13 I don't know. I got a very similar cheap one (they didnt have a proper flower-shaped one) in Jessops, and its not very good. Cuts out the corners too much, which means its a little big for my lens but still, its build quality leaves a lot to be desired, takes me about five minutes each time to screw the damn thing on. ---------------
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | jjonsalt wrote: Funny, some are willing to pay for a filter to 'protect' their lenses. Often for an expensive one even. But won't spring for a lens hood that will really 'protect' the lens and work/fit well (OE). A filter is a difficult to produce piece of optical glass. A hood is a press moulded piece of plastic. There is a slight difference there... "I think the idea of art kills creativity" - Douglas Adams
jjonsalt Goldmember 1,502 posts Joined Oct 2005 Location: Central Florida More info | Permanent banjoeseph wrote: I quite like my 24-70 hood. Can easily get the lenscap on & off with it still on, does it's job well, only thing that's a little fiddly is mounting the lens when the hood's reversed. Anyone else find this problem? Since my 24-70L is on my camera 80% of the time it's a small, if any, problem with me. René Damkot wrote: ...I can't fathom the idea of spending close to 400 euro's on a hood for the 500/4. F.Y.I. The hood comes with that lens.
| Latest registered member is slipper1963 1863 guests, 159 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
