Thread started 08 Jun 2014 (Sunday) 01:35
Canon 80-200mm 2.8 Lens Help
effstop
Jun 08, 2014 01:35 |  #1
Yes, I know that Canon does not service this antique lens but I have a minor issue that I'm hoping someone here can help me out with. The rubber zoom ring is stretched out and in desperate need of replacement.
I tried to find a replacement zoom ring on eBay and Amazon but can't seem to find one. Is there a current zoom ring that might fit the lens that can be substituted? Any DIY recommendations as I might used slap some gaffer tape?
5D MKI | 1D MKII | 24-70mm 2.8 L | 80-200MM 2.8 L | 400mm 5.6 L |50mm 1.8
jvk
Jun 08, 2014 07:31 |  #2
That is a very common issue with the lens, mine has it aswell.
An idea?: Cut it loose and shorten it a little bit, then glue it directly onto the lens. Dont know if that works.
Camera: Canon EOS 7D / Nikon Coolpix A / Hasselblad xpan
Lenses: Canon EF 16-35mm f/2.8L USM / Canon EF 24-105mm f/4L IS USM / Canon EF 80-200 f/2.8L / Canon EF 300mm f/2.8L USM
SeattleSpeedster
Gallery: 873 photos
Jun 08, 2014 15:20 |  #3
^^ the copy of this lens I used to have...someone had clearly done that to it
Fuji GFX100s and A7R II | Zeiss 85mm f1.4 Otus and 28mm f1.4 Otus | Fuji GF23mm, GF45-100mm and GF32-64mm | Canon 200mm f1.8 Canon 70-200mm 2.8 ii | Zeiss 100-300mm | Zeiss 16-35mm f4 | Zeiss 135mm f2 | Zeiss and Sony 50mm f1.4 | Mavic 3 Pro and Inspire 2 X7 drones | https://mikereidphotog​raphy.com (external link)
LightEtching
Joined Sep 2012
Jun 08, 2014 16:00 as a reply to  @ SeattleSpeedster's post |  #4
I don't know if it would work, but you could take it off, then put some wide superbands on the lens and then put the original stretched zoom ring over top of them. it might take up the slack and still provide a solid grip.
bratkinson
Joined Dec 2011
Jun 10, 2014 06:27 |  #5
I haven't tried it on mine, but I'm thinking a black Lens Band would have to be stretched to mount to the 80-200. If needed, a dab or two of rubber cement and you should be all set!
http://www.bhphotovide​o.com …es&sts=ma&Top+N​av-Search= (external link)
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." General George S Patton, Jr 1885-1945
jimewall
Jun 10, 2014 08:00 |  #6
bratkinson wrote in post #16962690 (external link)
Those look like those rubber wristbands that kids wear. They might not be, but they sure look like it. Those are probably a buck at a a dollar store if you dont care about a specific color - otherwise search.
Thanks for Reading & Good Luck - Jim
GEAR
1,552 views & 0 likes for this thread, 6 members have posted to it.
Latest registered member is EBiffany
1606 guests, 98 members online
