Here is what happened, I hope someone can help...Sorry if this is long.
I moved images to a sub-folder for import. They are MOVED into the folder, not copied. Therefore, they are absent from the original folder.
I then imported the images form the sub-folder into light room and strated processing. After processing each image, I exported them to a different "finished" folder within the original folder.
Half-way trhough, I clicked on the next image in my filmstrip view. It came up full screen with a message of "File not Found" and would not allow me to proccess it.
All the images from import (both finished and ones I hadn't worked on) were still visible in the filmstrip view but no matter what image I clicked on (including the finished ones) the same message appeared of "File not Found"
So I went to the subfolder where I orignally MOVED the images for import and it was completely empty (which explains "File not Found"). The finished images that exported to the "finished" subfolder were still there.
When I checked the original folder, all of the images were RETURNED to the folder. I did not do anything to move them there myself...
My question is... has this happened to anyone else and how to avoid it in the future?
Thanks in advance,
Emily
