What power neutral density filters, solid and graduated, are most often used for landscapes? should I buy them all?
1 stop
1.5
2.0
2.5
3.0
4.0
5.0
6.0
9.0
10.0
texshooter Senior Member 652 posts Likes: 26 Joined Jun 2009 More info | Jun 10, 2014 07:22 | #1 What power neutral density filters, solid and graduated, are most often used for landscapes? should I buy them all?
Sirrith Cream of the Crop More info | Jun 10, 2014 07:37 | #2 I find 3 stop graduated filters to be the most useful. For solids, it depends entirely on what you like. I have a 10 stop for really strong smoothing effects, and again a 3 stop for more "general" use. I can combine this with my GND turned upside down for 6 stops. -Tom
vengence Goldmember 2,103 posts Likes: 108 Joined Mar 2013 More info | Jun 10, 2014 09:16 | #3 3 stop GND (if not done in post either through bracketing or single exposure)
kfreels Goldmember 4,297 posts Likes: 11 Joined Aug 2010 Location: Princeton, IN More info | Jun 10, 2014 12:38 | #4 Anything below 4 stops probably isn't worth bothering with. You can usually make camera adjustments such as a single stop increase of shutter speed, one stop narrower on aperture, and 1 stop pulling the exposure back in post. Of course, the less you have to compromise, the better, but it is better than buying a bunch of ND filters. I am serious....and don't call me Shirley.
Hogloff Cream of the Crop 7,606 posts Likes: 416 Joined Apr 2003 Location: British Columbia More info | Jun 10, 2014 13:25 | #5 Permanent banI have a 2 stop soft and a 2stop & 3stop hard and a 10 stop ND filter and make use of them all the time. Really depends what and where you shoot. I also have a polarizer I quite often use with my other filters.
taemo Goldmember 1,243 posts Likes: 7 Joined Sep 2011 Location: Calgary, AB More info | Jun 10, 2014 13:33 | #6 My filters consist of earldieta.com
Jun 10, 2014 13:50 | #7 Square: 3, 10, 3 GND soft.... that's pretty much all I have. Might get a 3 GND hard and 4x4 polarizer to complete my setup, but I do tend to blend rather than relying on GND's. Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
Jun 11, 2014 04:11 | #8 A set of 3, 6 and 10-stoppers will cover most needs. If short of cash you can have just 3 and 6-stoppers and stack them when needed. Frank Hollis - Retired mass spectroscopist
Albino_BlacMan Member 78 posts Joined Apr 2012 More info | Jun 11, 2014 12:19 | #9 3 Stop (or less) won't help much for landscapes, it's really only good if you want to shoot wide in open in bright sunlight.
Jun 11, 2014 13:07 | #10 Albino_BlacMan wrote in post #16965458 3 Stop (or less) won't help much for landscapes, it's really only good if you want to shoot wide in open in bright sunlight. actually 3 is pretty good. 3 grads are great and effective. 3ND's also have a good purpose when the sun is setting or rising. Give just enough you buy you an hour of shooting, where 10 would be overkill. Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
bob_r Goldmember More info | Jun 11, 2014 20:26 | #11 Depending on your budget, you might want to consider getting a variable ND filter. They can be a little pricey, but if you're considering getting a number of the regular ones, this may be about as cheap. Canon 7D, 5D, 35L, 50 f/1.4, 85 f/1.8, 135L, 200L, 10-22, 17-55, 70-300, 100-400L, 500D, 580EX(2).
Sirrith Cream of the Crop More info | Jun 12, 2014 05:55 | #12 Albino_BlacMan wrote in post #16965458 3 Stop (or less) won't help much for landscapes, it's really only good if you want to shoot wide in open in bright sunlight. I use my 3 stop filters exclusively for landscapes. -Tom
Jun 13, 2014 20:43 | #14 |
svarley Senior Member 592 posts Likes: 13 Joined Mar 2009 Location: LA, CA More info | Jun 14, 2014 15:08 | #15 Speaking of GNDs and NDs... which ones are the good ones and which ones should be skipped? (brands, I mean)
| Latest registered member is semonsters 1034 guests, 109 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
