Thread started 14 Jun 2014 (Saturday) 19:31
600ex-rt Speedlight Question
Northwoods ­ Bill
Joined Jun 2012
Jun 14, 2014 19:31 |  #1
I am currently using 4 of the 600ex-rt for real estate photography. I am using Canon's radio transmitter to trigger them. The transmitter can only set three different power levels. A, B, and C. There are times I want each speed light to have its own power. Is there any way to do this? Also is there a way to set power right at the speed light but still trigger from the radio transmitter?
Thanks!
Bill R
Web:https://www.flickr.com​/photos/whitebirch/ (external link)
Submariner
Joined May 2012
Jun 14, 2014 21:02 |  #2
Northwoods Bill wrote in post #16971908 (external link)
Thanks!
Assuming you mean the STE 3' trigger.
Yes you can set a different flash mode for each of the groups ( max 5 I think) see p.18 of the manual.
Not sure if your camera is classified as a post 2012 camera? My 5D3 is , i do recollect some thing like, maybe pre 2012 cameras can not use Groups in wireless mode. Sorry as mine are post 2012 cameras Imdid not get into the limitations of cameras I do not own.
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
Northwoods ­ Bill
Joined Jun 2012
Jun 14, 2014 21:57 |  #3
Shooting with a 5diii. I will have a look at the manual for the ste3. Thanks
Bill R
pstyle1
Joined Jun 2012
Jun 15, 2014 00:38 |  #4
Use them in group mode and you can adjust each group anywhere from 1/1 or 1/128th power. So if you have four 600's set each of them to a different group (A,B,C & D) and you can control each one individually from the ste-3.
5D MkIII x2 + a lot of L's.
www.facebook.com/Peyma​nRazaviPhotography (external link)
Northwoods ­ Bill
Joined Jun 2012
Jun 15, 2014 06:22 |  #5
Thanks, for some reason my ste-3 was only showing groups a,b,c. Not sure if that is because I never set a flash to group d or e. I will experiment tonight.
Bill R
Submariner
Joined May 2012
Jun 15, 2014 07:36 |  #6
Northwoods Bill wrote in post #16972561 (external link)
I am pretty sure you need to set one of them to the 4th group for it to show up.
I am assuming there is some communication that advises the Ste3 of their existence.
agv8or
Gallery: 10 photos
Jun 15, 2014 08:13 |  #7
Submariner wrote in post #16972656 (external link)
All five groups A, B, C, D, and E will be availabe in the <Gr> mode without having a Slave set. You just need to scroll down through the groups on the Master.
Rand
Gear
apersson850
Obviously it's a good thing
Gallery: 35 photos
Jun 15, 2014 14:51 as a reply to  @ agv8or's post |  #8
Yes, but even when using radio mode the ST-E3-RT also supports the old setup, the one you can also use with optical communication. When using that method, only three groups are available (A, B and C).
So there could be a confusion of main modes here, not just which groups you can use.
Set the remote flash up via the camera's menu system instead. At least to being with, it's a lot easier to overview.
The optical system does allow you to set manual power settings at the flashes themselves, and then you can use as many flashes with as many settings as you care for walking around to set up. Such slaves are called Individual slaves. Not supported in radio mode, though.
Anders
Northwoods ­ Bill
Joined Jun 2012
Jun 15, 2014 18:53 |  #9
Thanks. Got it now. I was not in <gr> mode. That is going to be a big help at the next shoot.
Bill R
dmward
Gallery: 29 photos
Jun 15, 2014 23:16 |  #10
For real estate and architectural photography I've found using the 600EX-RTs in Gr ETTL mode is even easier than in M mode. With ETTL its possible to set each group with a plus or minus FEC to get the lighting scheme you want. Then use the FEC master to bring the whole scheme up or down to fine tune the over all exposure.
Sounds a lot more complicated to describe than to do. :-)
Northwoods ­ Bill
Joined Jun 2012
Jun 16, 2014 04:55 |  #11
I will give It a try. My only concern with ETTL is the possibility of the camera metering differently from shot to shot. I am blending in PS so I want my overall exposure to remain consistent. The blending is mainly light painting certain objects.
Bill R
Nick5
Jun 16, 2014 08:54 |  #12
dmward wrote in post #16974040 (external link)
That is sound advice dm.
Canon 5D Mark III (x2), BG-E11 Grips, Canon Lenses 16-35 f/4 L IS, 17-40 f/4 L, 24-70 f/4 L IS, 70-200 f/2.8 L IS II, 70-200 f/4 L IS, 70-200 f/4 L IS Version II, 100-400 f/4.5-5.6 L IS Version II, TS-E 24 f/3.5 L II, 100 f/2.8 L Macro IS, 10-22 f3.5-4.5, 17-55 f/2.8 L IS, 85 f/1.8, Canon 1.4 Extender III, 5 Canon 600 EX-RT, 2 Canon ST-E3 Transmitters, Canon PRO-300 Printer
dmward
Gallery: 29 photos
Jun 16, 2014 09:03 |  #13
Northwoods Bill wrote in post #16974294 (external link)
Not enough to worry about in my experience.
IMAGE: http://www.dmwfotos.com/architecture/galleries/hawthorn/photos/DMWA8023-5-806.jpg
This exterior shot is a blending of about 40 images. Most of them were details lit with a 600EX-RT on a stick in ETTL. There is another exterior twilight image that was shot at the same time. I had two cameras on tripods, each with an ST-E3 to trigger the stick light. I had two wireless remotes to trigger the cameras.
I think about 70% of the interior lights have some speedlite contribution.
HERE (external link) is the rest of the gallery.
Northwoods ­ Bill
Joined Jun 2012
Jun 16, 2014 09:06 |  #14
Wow. That is an impressive image. I was pretty pleased with what I came up with for my first try but I clearly have more to learn!
Bill R
3,217 views & 0 likes for this thread, 7 members have posted to it.
1293 guests, 136 members online
