Thread started 15 Jun 2014 (Sunday) 18:58
Mix 600-EX and Elinchrom RX-600
Northwoods ­ Bill
Joined Jun 2012
Jun 15, 2014 18:58 |  #1
Is there any way to easily fire both a few Canon 600-EX speed lights and an Elinchrom RX-600. What I am thinking of is a real estate shot with the speed lights inside and the RX-600 providing fake sunlight from outside. I have the Elinchrom remotes for their lights and the Canon STE3. Without buying pocket wizards or similar is there any way to trigger both?
Thanks in advance!
Bill R
Web:https://www.flickr.com​/photos/whitebirch/ (external link)
windpig
Chopped liver
Jun 15, 2014 22:21 |  #2
I assume there is no preflash with the 600-EX in manual mode, if so it may be possible to have this work by putting the RW-600 into optical firing mode. Else some cheap Yongnuo triggers and not use the STE3.
Go ahead, spin the wheel.
dmward
Gallery: 29 photos
Jun 15, 2014 23:20 |  #3
The only way to use the ST-E3 on camera and fire the Elinchrom is to use either a PC cable to the Elinchrom trigger, or a pass through trigger such as the Phottix Strato II. It goes on the camera, the ST-E3 goes in its hot shoe and then a Strato II receiver is connected to the Elinchrom light(s).
agv8or
Gallery: 10 photos
Jun 15, 2014 23:28 |  #4
Use a Phottix Stratos II transmitter and receiver ($100). The transmitter has pass through TTL which will allow for full functionality of your ST-E3-RT to control your 600EX-RT Speedlites in the Wireless RT system. Then you can use the receiver to directly trigger your Elinchrom or use it to trigger your Elinchrom transmitter if your strobe has a built in receiver (I do not know anything about Elinchrom flash units). In the following link I explain this setup. Just replace the 600EX-RT with an ST-E3-RT as at the time I posted this the ST-E3-RTs were not available.
https://photography-on-the.net …p?p=14486371&po​stcount=92
Rand
Gear
Northwoods ­ Bill
Joined Jun 2012
Jun 16, 2014 05:12 |  #5
agv8or wrote in post #16974051 (external link)
Thanks, that is exactly what I was looking for. Thanks dmward for the answer as well. I knew there had to be an answer and I knew if there was that this forum would come up with it.
Bill R
OneyedJack
Jun 16, 2014 11:03 |  #6
Have you considered getting an Elinchrom Skyport receiver to trigger the 600? It is fully compatible with the Skyports you already own. There is usually a used one on ebay for around $70 IIRC.
If you must use your existing equipment, you will need to use a PC cord to connect the Elinchrom transmitter to the camera with the STE3 in the shoe. Put the 600 in manual mode to avoid unpredictable results. Using a combination of ETTL flash and manual strobes is going to be very unpredictable while trying to over power the sun.
5Dmk2 | 24-105f4 | 16-35f2.8 | 70-200f2.8
windpig
Chopped liver
Jun 16, 2014 12:29 |  #7
Skyports suck, I've got 4 of them. I've gone the Yongnuo route, works great, pass through with full camera menuing working my 580EXII, along with multiple Elinchrom pacs.
dmward
Gallery: 29 photos
Jun 17, 2014 22:21 |  #8
windpig wrote in post #16975022 (external link)
Do the latest YN-60X offer pass through? That's good news.
ben_r_
-POTN's Three legged Support-
Jun 18, 2014 13:30 |  #9
I have trigger various flash guns (not mounted to the camera and always no E-TTL) and my 600RXs all with Skyports from the camera and from my laptop. They have always worked well for me.
Northwoods ­ Bill
Joined Jun 2012
Jun 18, 2014 13:36 |  #10
So I have the skyports that came with my Elinchrom lights. Am I to correct in understanding that I could cable one of these to the 600 and fire it?
Bill R
ben_r_
Jun 18, 2014 15:13 |  #11
Northwoods Bill wrote in post #16979685 (external link)
Not the ones that go into the RX heads, but you could use the cable output on the Skyport Transmitter to trigger a hotshoe adapter to fire the 600-EX. Or buy the Skyport Universal radio and that could be used to trigger a hotshoe adapter on the 600-EX.
Northwoods ­ Bill
Joined Jun 2012
Jun 18, 2014 15:22 |  #12
OK. Got it. Thanks!
Bill R
3,682 views & 0 likes for this thread, 6 members have posted to it.
1293 guests, 136 members online
