Thread started 15 Jun 2014 (Sunday) 21:46
Linear vs Circular
texshooter
Jun 15, 2014 21:46 |  #1
I read that a The only difference between a linear and circular polarizer is that the circular polarizer has a thin layer that reverses some of the polarizing effect so that the auto focus mechanism in the camera works correctly. I don't get it. What is the difference between reversing a fraction of the effect with a second layer and simply manufacturing the primary layer a little weaker. In other words, if the circular polarizer is too strong why not make the polarizer weaker rather than "reverse" or undo the effect with more glass?
Secondly, if this reversing layer reduces a portion of the light rays, then why does it have the same filter factor as the linear polarizer filter, which is 1.3 stops.
Thirdly, if I plan to use a polaring filter only with my manual focus 24mm TSE lens, then is there any advantage, other than price, of using a circular polarizer instead of the linear one?
davesrose
Title Fairy still hasn't visited me!
Jun 15, 2014 22:17 |  #2
texshooter wrote in post #16973923 (external link)
The second plate doesn't "reverse" the polarizing effect: it converts it to a circular polarized light. Apart from allowing AF, a circular polarizer is also more appropriate with DSLRs that have anti-alias filters. A linear polarized light can cancel out the anti-aliasing.
http://en.wikipedia.or​g …rizer#Circular_​polarizers (external link)
Canon 5D mk IV
EF 135mm 2.0L, EF 70-200mm 2.8L IS II, EF 24-70 2.8L II, EF 50mm 1.4, EF 100mm 2.8L Macro, EF 16-35mm 4L IS, Sigma 150-600mm C, 580EX, 600EX-RT, MeFoto Globetrotter tripod, grips, Black Rapid RS-7, CAMS plate and strap system, Lowepro Flipside 500 AW, and a few other things...
smugmug (external link)
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Jun 15, 2014 22:18 |  #3
Heya,
If you're shooting manual focus, the linear is often the choice.
Very best,
John ­ from ­ PA
Joined May 2003
Jun 16, 2014 07:11 |  #4
You are correct in this respect, but if you have some autofocus lenses as well then you need a circular anyway which will work on a manual focus lens. I do have to admit, you can find some linear polarizers out there in camera shops junk boxes for next to nothing in cost.
I also suggest you review the article at http://www.bobatkins.c​om …technical/polar​izers.html (external link) for a good explanation of both types of polarizers.
tkbslc
Jun 16, 2014 15:44 |  #5
There seems to be a wider selection of higher quality circular polarizers due to higher demand for them. But theoretically, no.
Taylor
EOS Rp | iPhone 11 Pro Max
farmer1957
Gallery: 6 photos
Joined Jul 2012
Jun 18, 2014 08:04 as a reply to  @ tkbslc's post |  #6
A technic called Cross polarization, the use of linear polarized film over your source of lighting and a CPL over on he lens.
What is the subject that you are photographing ?
Farmer
1,007 views & 0 likes for this thread, 6 members have posted to it.
Linear vs Circular
1034 guests, 109 members online
