Thread started 16 Jun 2014 (Monday) 09:00
AF micro adjustment: adjust all vs. adjust by lens
bacchanal
Jun 16, 2014 09:00 |  #1
When using AF micro adjustment, if you have a setting on "All by same amount" and a setting on "Adjust by lens" what is the setting that is used? Does one override the other or do they add together?
For instance, if you have:
All by same amount: +5
Adjust by lens: +8
Is the actual MA value used +5, +8, or +13?
I'm asking specifically about the 5DIII, but I assume MA works the same in other cameras as well.
KirkS518
Joined Apr 2012
Jun 16, 2014 09:10 |  #2
I have a 50D, and it only allows you to pick one or the other. It's either all or one, so (and this may be me just not being familiar with the 5DII), I don't think you can have both options selected. ???
If steroids are illegal for athletes, should PS be illegal for models?
Digital - 50D, 20D IR Conv, 9 Lenses from 8mm to 300mm
Analog - Mamiya RB67 Pro-SD, Canon A-1, Nikon F4S, YashicaMat 124G, Rollei 35S, QL17 GIII, Zeiss Ikon Ikoflex 1st Version, and and entire room full of lenses and other stuff
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Jun 16, 2014 09:17 |  #3
It will use whichever setting you have active at the time.
rrblint
Gallery: 84 photos
Joined May 2012
Jun 16, 2014 09:28 as a reply to  @ Snydremark's post |  #4
You have to choose one or the other. It will only use the one that you choose.
Mark
bacchanal
Jun 16, 2014 09:29 as a reply to  @ Snydremark's post |  #5
I don't have my camera in front of me, but I'm sure you can put a value in both settings on the 5D3. Maybe I'm just crazy.
rrblint
Gallery: 84 photos
Joined May 2012
Jun 16, 2014 09:44 |  #6
You have the choice of either:
1.) Disable
2.) Adjust by the same amount
3.) Adjust by lens
Which ever one you choose will be used by the camera even if information is entered for each choice.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/06/3/LQ_687876.jpg
Image hosted by forum (687876) © rrblint [SHARE LINK]
Mark
Gregg.Siam
Joined Jun 2010
Jun 16, 2014 10:12 |  #7
bacchanal wrote in post #16974666 (external link)
Sure, but it doesn't mean it uses both at the same time.
You need to adjust by lens and leave it at that. The odds of you having multiple lenses off by the same amount is zero.
5D MKIII | 24-105mm f/4 L| 50mm f/1.8 | 600EX-RT [FONT=Tahoma][COLOR=bl​ue][FONT="]|
∞ 500px (external link)
LV ­ Moose
Moose gets blamed for everything.
Gallery: 223 photos
Jun 16, 2014 10:33 |  #8
Gregg.Siam wrote in post #16974747 (external link)
I know. Why would they even have that option?
Moose
Gear... Flickr (external link)...Flickr 2 (external link)...
Macro (external link)...Hummingbirds (external link)
Aircraft (external link)
NullMember
Jun 16, 2014 10:38 |  #9
bannedPermanently
LV Moose wrote in post #16974775 (external link)
Because if they didn't people would complain.
LV ­ Moose
Gallery: 223 photos
Jun 16, 2014 10:41 |  #10
john crossley wrote in post #16974789 (external link)
You may have a point.
Moose
bacchanal
Jun 16, 2014 10:50 as a reply to  @ LV Moose's post |  #11
The camera can be off by a certain amount, just like the lens can. Adjust by all essentially moves the camera's zero point. So, if you're borrowing a lens or shooting with another photog's gear (say, second shooting at a wedding), you're at least at your body's zero point when you put the borrowed lens on. On my 5D3, I use a +5 and that seems to be just about perfect with several lenses.
My question is if I have a lens that needs a little bit more adjustment, what happens if I have adjustments in both settings. Does one override the other or is it cumulative. I can test it when I get home, but I just figured someone would know off the top of their head. It seems the assumption is that the lens setting overrides the adjust all setting.
rrblint
Gallery: 84 photos
Joined May 2012
Jun 16, 2014 11:11 as a reply to  @ bacchanal's post |  #12
You must CHOOSE ONE SETTING OR THE OTHER.
If you choose "Adjust by the same amount" the amount that you have filled in will be used.
If you choose "Adjust by lens" the amount filled in for that lens will be used.
YOU CANNOT CHOOSE BOTH AT THE SAME TIME.
Mark
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jun 16, 2014 11:13 |  #13
The option is there to adjust the camera if it is off by a certain amount. I think in the real world this is unlikely to be the best bet, but long before MA was available, we used to send our bodies back to Canon to have micro-adjustment done to body which would make the body work better with all lenses. ie: the body could be off front or back focus a certain degree.
CDS' HOT LINKS
LV ­ Moose
Gallery: 223 photos
Jun 16, 2014 11:18 as a reply to  @ CyberDyneSystems's post |  #14
ok. Makes sense.
Moose
bacchanal
Jun 16, 2014 12:34 |  #15
rrblint wrote in post #16974851 (external link)
Except you CAN enter values in both settings at the same time. I'm asking for specific clarification on what happens when that is the case. Does Adjust by lens override the all lens setting (or vice versa) or is it cumulative.
I guess I'll just test it myself.
4,029 views & 0 likes for this thread, 14 members have posted to it.
1014 guests, 107 members online
