Hi Guys
which should I be using ?
What shortcomings or benefits are there for either one?
I just noticed tonite that my 5D3 has been set to sRGB
I use Elements 11 for the majority of my editing, if that makes any difference ?
thanks lots
Dave
Davenn Senior Member More info | Jun 17, 2014 03:27 | #1 Hi Guys A picture is worth 1000 words
magwai Goldmember 1,094 posts Likes: 17 Joined Mar 2010 Location: Guildford, UK More info | Jun 17, 2014 03:44 | #2 Based on personal experience, if you don't want to spend the time to fully understand and manage this then stick to sRGB. I shoot raw in any case so I only need jpg for web and print as a final step.
CRCchemist Senior Member 961 posts Likes: 19 Joined Apr 2014 More info | Jun 17, 2014 03:44 | #3 Davenn wrote in post #16976467 Hi Guys which should I be using ? What shortcomings or benefits are there for either one? I just noticed tonite that my 5D3 has been set to sRGB I use Elements 11 for the majority of my editing, if that makes any difference ? thanks lots Dave It matters for what you print. Wherever you take your images to print them, will have instructions that tell you what color space to use. Some printers are at an advantage in sRGB, more others look better in AdobeRGB, and other printers will look best in ProPhotoRGB. You just have to research which one you need for what you use to print.
Paulstw Senior Member 827 posts Likes: 2 Joined Nov 2012 More info | Jun 17, 2014 04:00 | #4 Stick to sRGB because if you value your sanity and time it's not worth going to anything unless you print. I messed around for a wee while using PROphotRGB and when I viewed my pics on iOS devices and chrome they had a green hue to them. Went straight back to sRGB right away but I wasted a lot of time.
Jun 17, 2014 04:01 | #5 Thanks for the responses A picture is worth 1000 words
Jun 17, 2014 04:03 | #6 OK Paul A picture is worth 1000 words
Gregg.Siam Goldmember 2,383 posts Likes: 1 Joined Jun 2010 Location: Bangkok More info | Jun 17, 2014 04:54 | #7 Davenn wrote in post #16976498 OK Paul so from your and CRC's comments, 'this has more to do with image printing than anything else ? Not just printing. If you are putting images on the web, it should be sRGB as the web is not really optimized for anything else. Unless you have a good monitor with a wide gamut, it might not even see the full spectrum of AdobeRGB. 5D MKIII | 24-105mm f/4 L| 50mm f/1.8 | 600EX-RT [FONT=Tahoma][COLOR=blue][FONT="]|
Jun 17, 2014 05:23 | #8 thanks lots for your comments and links A picture is worth 1000 words
Maxdave Goldmember More info | Jun 17, 2014 05:53 | #9 Gregg.Siam wrote in post #16976527 Not just printing. If you are putting images on the web, it should be sRGB as the web is not really optimized for anything else. Unless you have a good monitor with a wide gamut, it might not even see the full spectrum of AdobeRGB. You can work in AdobeRGB or ProPhoto RGB then convert it depending on where it will be viewed. So if it's going on the web, convert it to sRGB. So to answer your question, I would shoot in AdobeRGB, work in AdobeRGB (Lightroom for example) then convert it to sRGB in post. This explains it better than I could. http://fstoppers.com/adobergb-vs-srgb A little about ProPhotoRGB http://www.luminous-landscape.com/tutorials/prophoto-rgb.shtml Exactly what I do ... if you shoot in Adobe RGB and have that RAW, you have the flexibility to remain in that gamut throughout post-processing, or change to sRGB if that is required at any point. 5D3,1D4,S90,6S&Moment Lenses,Hero4Silver,GPS-E2,2x580EX,430EX,90EX,EF16-35L f/4 IS,Samy SYTS24-C 24TS,EF24-105L IS,EF50 f/1.4,EF70-200 f/4L IS,EF300 f/4L IS,EF100-400L I IS,Kenko DGX 1.4X,Canon 2X TC Mk II, RRS&Pro-Media L-Brackets,Manfrotto MHXPRO-3WG & Roller 50,Sirui 306&K-20,Giottos MT-7371&MH-3300,Velbon ElCarmagne 530,CamRanger,Phottix&Canon Remotes,Lowepro Backpack,ThinkTank Retro 20&Modular System,OpTech straps,Lexar/San Disk Cards
JohnfromPA Cream of the Crop 11,258 posts Likes: 1527 Joined May 2003 Location: Southeast Pennsylvania More info | Jun 17, 2014 07:06 | #10 Paulstw wrote in post #16976494 I messed around for a wee while using PROphotRGB and when I viewed my pics on iOS devices and chrome they had a green hue to them. Went straight back to sRGB right away but I wasted a lot of time. Is a "wee while" similar to a wee peek? Leave it to the Black Watch! Image hosted by forum (687955) © John from PA [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | Jun 17, 2014 08:55 | #11 The only time I use sRGB is when I post an image on the web. The rest of the time I use AdobeRGB. Richard
Paulstw Senior Member 827 posts Likes: 2 Joined Nov 2012 More info | Jun 17, 2014 09:49 | #12 John from PA wrote in post #16976647 Is a "wee while" similar to a wee peek? Leave it to the Black Watch! lol it is indeed.
agedbriar Goldmember 2,657 posts Likes: 399 Joined Jan 2007 Location: Slovenia More info | Jun 17, 2014 13:46 | #13 Lowner wrote in post #16976843 The only time I use sRGB is when I post an image on the web. The rest of the time I use AdobeRGB. It simply produces a better print on a printer that can use it, which my Epson R2880 can and does. If you save to AdobeRGB an image that fits entirely into the sRGB gamut, you only get an image file with a lower number of colors (about 30% less, but depends on image) and no printer can bring them back.
rrblint Listen! .... do you smell something? More info | Jun 17, 2014 13:57 | #14 John from PA wrote in post #16976647 Is a "wee while" similar to a wee peek? Leave it to the Black Watch! Guess it's true what they say about men who wear kilts. Mark
JohnfromPA Cream of the Crop 11,258 posts Likes: 1527 Joined May 2003 Location: Southeast Pennsylvania More info | Jun 17, 2014 15:05 | #15 The Scots actually have a name for it; when wearing the kilt, it is customary for troops to "go regimental" or "military practice" meaning no underwear. The Black Watch (in the picture) are notorious at adhering to tradition.
| Latest registered member is semonsters 1062 guests, 115 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
