Thread started 19 Jun 2014 (Thursday) 16:28
5D3 focus issue with 100-400 (outer points)
Frosticles
Gallery: 37 photos
Joined Oct 2012
Jun 19, 2014 16:28 |  #1
Not sure really where to start. Previously owned a 7d & coupled together with the 100-400 was fantastic & never missed focus in a1 servo on all 19 points. Have now changed to a 5D3 & am having problems with it focusing in A1 servo on the very outer focus points. It seems to drag & hunt whereas the 7d locked straight away.
Hoping it is something simple. All help greatly appreciated.
Kind regards, Kevin.
Kind regards, Kevin
My Fickr - http://www.flickr.com/​photos/28825728@N08/ (external link)
apersson850
Obviously it's a good thing
Gallery: 35 photos
Jun 20, 2014 05:27 |  #2
Try first to use the cross type points only, to see if that improves things.
Anders
Frosticles
Gallery: 37 photos
Joined Oct 2012
Jun 20, 2014 09:05 |  #3
apersson850 wrote in post #16983019 (external link)
Hi there, Yes, have tried these. The outer ones are cross type. Problem is persisting :(
Kind regards, Kevin
Paulstw
Joined Nov 2012
Jun 20, 2014 09:37 |  #4
The 5D3 AF system is more complex than my ex wife.
http://cpn.canon-europe.com …_AF_setting_gui​debook.pdf (external link)
That's the user guide for the AF system and it'll tell you what AF points are active with what lenses and widest apertures.
Apparently 21 cross type AF points can be used with that lens and other f/5.6 lenses.
rrblint
Gallery: 84 photos
Joined May 2012
Jun 20, 2014 10:25 as a reply to  @ Paulstw's post |  #5
For the lens that you are using, only the central 21 points are cross type:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/06/3/LQ_688127.jpg
Image hosted by forum (688127) © rrblint [SHARE LINK]
Mark
Frosticles
Gallery: 37 photos
Joined Oct 2012
Jun 20, 2014 11:01 |  #6
rrblint wrote in post #16983513 (external link)
Hosted photo: posted by rrblint in
./showthread.php?p=169​83513&i=i162025891
forum: Canon Digital Cameras
Thank you for that. Greatly appreciated. What I can't understand though is that it was perfect on the 7D but hunts on the 5D3. Were all the 19 points on the 7D Cross type with this lens?
Kind regards, Kevin
rrblint
Gallery: 84 photos
Joined May 2012
Jun 20, 2014 12:23 |  #7
Frosticles wrote in post #16983591 (external link)
According to the 7D manual no, provided that the lens is racked out far enough so that the maximum aperture becomes f5.6. I suspect though that it's not a hard cut-off when the lens hits f5.6 and that the cross-type points may continue to work for some focal lengths even after the lens reaches f5.6(just guessing here though).
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/06/3/LQ_688131.jpg
Image hosted by forum (688131) © rrblint [SHARE LINK]
Mark
Frosticles
Gallery: 37 photos
Joined Oct 2012
Jun 20, 2014 14:13 as a reply to  @ rrblint's post |  #8
It's only the outer ones that are hunting. All the others seem to be fine
Kind regards, Kevin
1,770 views & 0 likes for this thread, 4 members have posted to it.
925 guests, 118 members online
