the jimmy wrote in post #16988114
Great shot for sure, how did ML help with this?
Thanks Jimmy. I used ML's intervalometer to take a specific amount of images all in a row. Without the intervalometer I would have had to hit the shutter for every shot and possibly shaken the camera out of align while doing so. I also used ML's Sound trigger to take a picture whenever I wanted without having to touch the camera. I set the trigger to snap a picture when I clapped but not sensitive enough that talking would trigger it. ML's got some really neat features IMO.
SteveInNZ wrote in post #16988127
Sometimes we forget what's important in a hobby. Well done.
Much nicer stars in this one than the one in the "don't need a telescope" thread. Is it the same lens and if so, how far was it stopped down ?
I'm also curious about how ML helped.
Steve.
Cheers Steve. Yeah, same 50 f1.4 lens. I found the minimum speed I could get away with without bad coma was f3.5
I'm gonna try the 85mm f1.8 tonight and see if that suffers the same problem.
I was also in a darker zone which I think helped a lot.
weisun wrote in post #16988795
mine sharing the setup for the 60 images?
No problem Weisun.
6D with 50mm @ f3.5
ISO 8000
6 seconds
The 6D was attached firmly to a tripod with magic lantern running the intervalometer taking continuous 6 seconds exposures. My own rule of thumb is a minimum of 20 Dark and Bias frames while stacking. Because 6D's are already fairly good at handling noise, I figured I wouldn't need more than 60 exposures to eliminate most of it.
I learn't how to stack from Baz's tutorial here on the forum and also this really good guide to using Deep sky stacker. https://www.youtube.com/watch?v=e0JSTF8SGi4
