Thread started 23 Jun 2014 (Monday) 18:08
Looks like I have a problem with my 7d
Nascar ­ Nut
Joined Feb 2004
Jun 23, 2014 18:08 |  #1
My wife and I went to Yellowstone a few weeks ago and I took a lot of photos. I have gone through about 2000 photos now so far and I have had 6 photos that were similar to this one. Does anyone know what is going on to cause this? This was shot with my 7d and 100-400 lens. Looks like I may have a real problem with my camera.
IMAGE: http://the-outdoorsman.net/temp/IMG_8397062314.jpg
Numenorean
Jun 23, 2014 18:10 |  #2
Most likely a bad memory card.
Go4EVA!
Jun 23, 2014 18:12 as a reply to  @ Numenorean's post |  #3
+1 Pretty sure it's a problem with your memory card.
TJays
Joined Mar 2013
Jun 23, 2014 19:45 |  #4
Numenorean wrote in post #16990326 (external link)
bw! Might be time for a new one
Regards
Terri Jean
5D4 Gripped-EOS 1DX Markll -600mm/4.0 II L-35-350mm/3.5 L-70-200/2.8 L-24-70mm/2.8 L-85mm/1.2 II L-50mm/1.2 L
3Rotor
Gallery: 72 photos
Jun 23, 2014 19:57 |  #5
First thought as well, try memory card first.
Instagram (external link)
www.jessemak.com (external link)
Nascar ­ Nut
Joined Feb 2004
Jun 23, 2014 20:24 |  #6
Thanks for the tip. Is there any kind of test I can do. I have seven different cards I used and I transferred them to a portable hard drive. So I have no idea which card I used.
sandpiper
Jun 23, 2014 20:44 |  #7
Nascar Nut wrote in post #16990516 (external link)
Have you formatted or reused the cards yet? If not, just see which ones have those images on them.
If it only happened to a few frames, I would just use the cards again and see what happens. The dodgy card will probably show up the same way, so just download and check each one individually.
Whilst a bad card is a likely suspect, it could also be anything in the transfer process, a bad lead or the portable hard drive for example. If you spot it again, put that card back in the camera and look at the faulty frames on the back of that. If they still look faulty, it is probably the card, if the fault doesn't show then it is more likely that it is being caused during the transfer process, so probably a lead or card reader if you use one.
It may take a little detective work to trace the problem, but the good news is that it is unlikely to be the camera at fault (but not impossible).
GeoKras1989
Joined Jun 2014
Jun 23, 2014 20:57 |  #8
I think getting that close to a mama black bear with a cub is a bigger problem than whatever is going on with your camera. Even at 400mm, you are what 40 yards from her? That is certainly within charging range. Please, be careful.
WARNING: I often dispense advice in fields I know little about!
apersson850
Obviously it's a good thing
Gallery: 35 photos
Jun 24, 2014 01:44 as a reply to  @ GeoKras1989's post |  #9
Getting closer will solve all his issues with any memory card...
Anders
Gochugogi
Jun 24, 2014 04:01 |  #10
I had exactly the same artifact pattern appear on a bunch of my 7D images. I tried another card and it never happened again and that was a few years back.
"I'm tryin' to think but nuttin' happens" -The Three Stooges
Ma Cool Digs (external link)
Canon ­ Amateur
Gallery: 50 photos
Jun 24, 2014 04:40 |  #11
I also had the same issue. In my case it was a bad quality card reader. Once I replaced the 42-in-1 cardreader for a SANDisk CF Card reader, I never had this issue again.
Canon EOS 1Dx / 5D4 / 5Dsr / Fujifilm X-T4 / Lytro illum
Nascar ­ Nut
Joined Feb 2004
Jun 24, 2014 05:22 |  #12
I have formatted most of the cards but I am going to check the ones I didn't and see if the bad images are on any of those. I am using a sandisk card reader to transfer my files to the laptop and then copy the files from the laptop to the portable hard drive. I did this so I had to copies of my photos just incase while on vacation. I then used the portable hard drive to copy the files to my home pc. I am going to look on my laptop and see if the files are corrupt on it as well. I will get it figured out. As for being close to the bear and cubs the rangers where right there along with a crowd of people. We were between 50 and 60 yards most of the morning. The ranger said this bear stays close to the road as her mom did because the male bears will most likely stay away from her cubs and not kill them because they don't like all the crowds of people. So she is a smart bear.
Aeroman
Jun 24, 2014 15:32 |  #13
I had something similar but it was a solid grey instead of the white block with lines. It turned out to be a bad sensor and was replaced.
Nascar ­ Nut
Joined Feb 2004
Jul 06, 2014 19:21 |  #14
Looks like it was my portable hard drive. I looked at the bad files on my laptop and they are all good on there. So it must have happened when I transferred the photos from my laptop to backup on my portable hard drive as the files are bad on that drive and those are the files I copied to my home pc to edit the photos.
3,023 views & 0 likes for this thread, 11 members have posted to it.
1039 guests, 107 members online
