ed rader wrote in post #16991609
on my recent road trip to and through Utah I noticed my 24-70L II intermittently would throw a severely underexposed frame followed by one that was way overexposed. and then it would perform normally for awhile.
the problem could be worse in the heat because it seems like in the 100-degree days it was worse and in the 50 or so frames I shot in death valley the problem occurred maybe three times.
the lens is going in today but do these symptoms sound familiar to anyone? thanks.
This is exactly the symptoms of a failing aperture diaphragm. I had this on my Sigma 28-300 on a very hot day in the sun. Sometimes after taking a shot stopped down, the iris wouldn't re-open although the camera thought that it had. The viewfinder is a bit dimmer of course but on a sunny day you don't always notice. The next shot is then metered with the iris partly closed but the camera thinks it is open so when you take the next shot, it is overexposed. After it cooled, it seemed ok.
You can check for it by putting the camera in Av or M mode and pressing the depth of field preview button repeatedly while looking into the end of the lens and trying different f-stops. It should be snappy and always reopening all the way at every f-stop. If not, you may want to get the aperture replaced.
