Thread started 25 Jun 2014 (Wednesday) 00:26
will the sandisk extreme pro 95mb/s still hit the 6D's camera buffer in RAW?
the.forumer
Joined Oct 2011
Jun 25, 2014 00:26 |  #1
as above - i just purchased the mid-tier version (45mb/s) for use on my 6D, in RAW-only mode. disappointed to see that it is still not fast enough to prevent hitting the buffer.
any idea if the 95mb/s will perform well and maintain the fps rate?
thanks!
mine1
Joined Jun 2012
Jun 25, 2014 02:00 |  #2
I don't think it is possible in any camera to not hit the buffer limit.
http://www.flickr.com/​photos/81190407@N08/ (external link)
Canon 60d.Canon 18-135, 55-250 II, and 10-18 stm. and Benro C-1681t Travel Angel, with Sirui K20x head.
hollis_f
Jun 25, 2014 06:59 |  #3
the.forumer wrote in post #16992919 (external link)
I'm not sure about the 6D, but I know that with the 50D and 7D card speed made no difference to the number of shots to fill the buffer. On the 7D I tried a 60MB/s card and a 1.5MB/s card - both filled the buffer with the same number of shots.
mine1 wrote in post #16993026 (external link)
I'm pretty sure this is true if shooting raw. With jpegs it may be a different story.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
apersson850
Obviously it's a good thing
Gallery: 35 photos
Jun 25, 2014 08:57 as a reply to  @ hollis_f's post |  #4
Sure, the 6D is slower, but the 1DX at full speed produces over 350 MBytes/s. Obviously the cards you are looking at are far from that.
Regardless of this, it has been shown that several camera models don't write to the card whilst shooting when using RAW. So a faster card allows quicker recovery, but not longer bursts. As stated above, that probably is true still for all of them, although I don't know for sure.
Anders
hollis_f
Jun 25, 2014 12:36 |  #5
apersson850 wrote in post #16993441 (external link)
My ancient memory may be playing up again, but I seem to recall that somebody tested the 5D MkIII and came to the conclusion that it did write to the card while writing to the buffer and that card speed did affect buffer capacity. But I may be mistaken.
Jon
Joined Jun 2004
Jun 25, 2014 13:38 |  #6
Starting with, IIRC the 5Dc and maybe the 30D, Canon was touting "write-through" buffers, where the buffer would be reading the sensor while writing to the card.
Jon
Cocker Spaniels
hollis_f
Jun 25, 2014 16:57 |  #7
Jon wrote in post #16993971 (external link)
Well, it definitely didn't implement it on the 50D or 7D when shooting raw.
johnf3f
Jun 26, 2014 17:09 |  #8
I don't have a 5D3, but on my 1DX switching between a Transcend 400x card and a Lexar 1000x card yields approximately 20 more RAW files before the camera slows. On other cameras that I have tried with fast vs (relatively slower cards) the difference is less with cameras such as the 40D and 1D3 only showing 2-4 frames difference, though with the faster cards the buffer does clear much faster.
Life is for living, cameras are to capture it (one day I will learn how!).
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Jun 26, 2014 17:49 |  #9
hollis_f wrote in post #16994361 (external link)
With my 5DII card speed can make a big difference. With the latest generation of Sandisk Extreme (gold label) the camera never stops shooting, it just slows down. With my older Ultra/Ultra II/Extreme III cards it will outright stop, then take a shot, then stop, repeat.
500px (external link)
1x (external link)
instagram (external link)
shocolite
Gallery: 55 photos
Joined Mar 2014
Jun 27, 2014 05:32 |  #10
I recently bought a Sandisk Pro 95mb/s SD card to see if it would improve upon the performance of the 45mb/s Sandisk version in my 6D. Made no difference whatsover, I tried full raw, small raw, raw & jpeg etc. No differnce whatsoever. I tried turning off any of the in-camera features that improve images etc - still made no difference. I will stick to 45mb/s if I need more cards in the future.
Canon 80D, 700D & G7 X; EF-S 10-18/18-135 STM, EF-S 18-135 IS USM, 50 F1.4, 100 F2.8L Macro, 16-35 F4L, 70-200 F4L IS; 100-400 L II, Speedlite 430EX II
dkizzle
Joined Mar 2012
Jun 27, 2014 06:49 as a reply to  @ shocolite's post |  #11
I do not know how the buffering works with Canon but I do many years of experience in IT and know how storage works. Camera takes a continuous sequence of pictures, uses buffer and starts saving the pictures to a memory card. The camera now has data to move the card and the speed of the card determines how fast the data will move. Slower cards would create slower write speeds and cause a bottleneck of the data transfer.
Try using 2 very different cards for a controlled test. 15mb/s versus 45mb/s would be easier to tell a difference when using 2 super fast cards. You can also try shooting in JPG and see if that makes any difference. The camera processes RAW file to be displayed as JPG on the LCD and this is done in camera. Could it be that the buffer of the camera is used for capture of the RAW file as well as extra processing to add JPG data to the same file.
I want to guest blog on your Landscape / Travel photography blog, PM for details
hollis_f
Jun 27, 2014 07:04 |  #12
I've done an experiment comparing the number of raw shots it takes to fill the buffer of the 7D when using various speed CF cards. Here's the thread describing the experiment - LINK
For those who don't want to read the whole thing here's the results.
IMAGE: http://www.frankhollis.com/temp/CF%20Buffers%20small.jpg
You can see there's no difference in the numbers of files before the buffer fills (although the 60MB/s card seems to have one more shot, close examination shows there's a larger gap before that extra one). If the camera were writing to the 45MB/s card while the burst was happening then, in the two seconds it takes to fill the buffer, the camera would be able to write 90MB - or almost 4 raw files. But it can only manage the same as the 1.5MB/s card.
The conclusion is that the 7D does not write to the card whilst filling the buffer.
i-G12
Wat?
Gallery: 254 photos
Jun 27, 2014 07:27 |  #13
The way it was explained to me is that the camera(s) can only hold so much data in the buffer regardless of the speed of the card. The download speed from the camera to the computer, however, will be faster with the faster cards (I'm told). Pretty much the difference is really negligible so it seems the 45MBs are good enough. Really not going to make any difference in the buffering in-camera.
Lay
Joined Oct 2013
Jun 27, 2014 09:15 |  #14
There is a huge difference on the 5D III if you use a slow card or a fast card.
See the link below
http://robgalbraith.co​m/index-2.html (external link)
Select "CF/SD/XQD" and then choose a camera model
hollis_f
Jun 27, 2014 09:31 |  #15
Unfortunately, Rob doesn't measure the number of shots before the buffer fills. He measures the number of shots in 30s. So the camera (1) fills the buffer, then (2) starts writing to the card until there's space in the buffer, then (3) takes more shots - goto (1). Obviously, the faster it does step (2) the faster it gets to step (3) and the faster it can repeat.
But it gives you no idea at all as to how many shots will fill the buffer.
4,276 views & 0 likes for this thread, 12 members have posted to it.
1504 guests, 134 members online
