Thread started 25 Jun 2014 (Wednesday) 17:21
First pictures with flash
hang ­ your ­ cross
Joined Dec 2013
Jun 25, 2014 17:21 |  #1
My new Yongnuo YN-500EX came in today and I've never used flash before. This is on the camera and this is basically one of the first shots. I bounced it off my 9' white ceiling.
Shot at f/2.2 1/180th and 400 ISO on my 50L
IMAGE: https://farm6.staticflickr.com/5595/14507140622_a9dc0fdb56_b.jpg
IMAGE LINK: https://flic.kr/p/o6WT​ub  (external link) flashtest01 (external link) by crxgator (external link), on Flickr
This is the same room without the flash at f/1.8, 1/160th and 400 ISO.
IMAGE: https://farm4.staticflickr.com/3922/14506923324_308e833d9d_b.jpg
IMAGE LINK: https://flic.kr/p/o6VL​TE  (external link) flashtest00 (external link) by crxgator (external link), on Flickr
I have not altered the pics at all. Any critiques or advice I could use?
Some of my feedback
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Jun 25, 2014 17:33 |  #2
try mixing ambient with flash. what you have shown with the two photos is that all the light is coming from one spot. bouncing is great, but one source of light is still one source of light, it will always be a bit harsh.
once you can achieve a balance between the two, use a different angle/positioning with the flash to put that light where you want it. Then it will become a way of modeling the face rather than a blast of light that makes flat light on the subject.
hang ­ your ­ cross
Joined Dec 2013
Jun 26, 2014 06:46 |  #3
I was trying to practice with on-camera flash as I will be shooting a wedding (not paid, nor in a professional manner; more for practice) this upcoming Friday and this is the only flash I will be using if I need to.
So I should bump up my ISO and lower the flash power to achieve a better light for my example?
Some of my feedback
groundloop
Joined Jun 2012
Jun 26, 2014 07:19 |  #4
hang your cross wrote in post #16995292 (external link)
Exactly. OR dropping the shutter speed (if possible) would add to the ambient exposure as well (the flash happens so quickly that shutter speed doesn't affect how much light from the flash gets into the shot).
Something else you can experiment with while bouncing flash is putting a white index card (or whatever) behind the flash so that a portion of the light is thrown forward as fill. You can simply hold it in place on the flash with a rubber band, lower it to have less light thrown forward, raise it for more.
Also, here's a great source for learning about lighting:
http://strobist.blogsp​ot.com/2006/03/lightin​g-101.html (external link)
heathermc72
Joined Feb 2014
Jun 26, 2014 09:43 |  #5
You don't need to lower your flash power. Bump your ISO up and bring your shutter speed down. This will close down the difference between the available light and the light your flash needs to produce to fulfill your exposure settings. You will need to ride your FEC setting up and down, depending upon the situation.
Gallery: 15 photos
Joined Jun 2011
Jun 26, 2014 09:58 |  #6
hopefully you will have a bit more light at the wedding, but yeah with the 6D you can easily go ISO 1600 if needed.
groundloop
Joined Jun 2012
Jun 26, 2014 10:55 |  #7
heathermc72 wrote in post #16995599 (external link)
Huh???
The first photo posted is properly exposed using just light from the flash. If the flash power stays the same AND the ISO is increased that shot will be overexposed.
heathermc72
Joined Feb 2014
Jun 26, 2014 14:25 |  #8
@groundloop: I presumed that the OP was shooting in TTL mode, not using it in manual. If he is adjusting the flash manually, then yes, you are exactly right and what I suggested would cause him to overexpose.
1,543 views & 0 likes for this thread, 4 members have posted to it.
1106 guests, 111 members online
