Thread started 26 Jun 2014 (Thursday) 20:02
HELP! Beach wedding post processing issue
acevesf
Joined Nov 2010
Jun 26, 2014 20:02 |  #1
Hi guys - need some help. I took a friends wedding pix in Cancun last week, the images looked GREAT when I was taking them on the back of the camera (jpeg preview). however, now when I import the raw files and try to process them I'm having serious issues getting the same look as the jpeg preview.
Also, for some reason it seems as if the left side of the frame is softer than the rest of the image, it's apparent in several pictures too :(
Any help you can provide would be appreciated, I've put a jpeg of the raw image below and uploaded the cr2 to dropbox.
https://www.dropbox.co​m …Garcia%20Weddin​g-8659.CR2 (external link)
IMAGE: https://farm3.staticflickr.com/2939/14329683459_af1a409618_o.jpg
IMAGE LINK: https://flic.kr/p/nQgn​DV  (external link) Garcia Wedding-8659 (external link) by Fernando Aceves (external link), on Flickr
Jarvis ­ Creative ­ Studios
Gallery: 28 photos
Joined Aug 2013
Jun 26, 2014 20:19 |  #2
Is this more what you had in mind? Looks like the exposure is just down a bit. Sorry about the watermark. It automatically adds to all my pictures and I forgot to disable it.
wedding (external link) by Jarvis Creative Studios (external link), on Flickr
WEBSITE (external link)
Sony ZV-1 || Sony a7RIV || Sony a9 || Sony a1 || Sony FE 20mm f1.8 G || Sony FE 24-70 f2.8 GM || Sony FE 50mm f1.2 GM || Sony FE 90mm f2.8 Macro G OSS || Sony FE 135mm f1.8 GM || Sony FE 200-600 f5.6-6.3 G OSS || Godox speedlights and strobes
eNTiTy
Joined May 2014
Jun 26, 2014 20:32 |  #3
It's tilted... or... has the world turned to the side? I'm sure you can easily fix that.
Entity = NTT = Natalie
6D | 40D | 17-35 f/2.8L USM | 24-70 f/2.8L USM | 28-135 f/3.5-5.6 IS USM | 24-105 f/4L IS USM | 40 f/2.8 | 50 f/1.8 MkI | 85 f/1.8 USM | 70-210 f/4 (1st gen-can't seem to let it go :o) | 70-200 f/2.8L IS USM
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Jun 26, 2014 21:15 |  #4
Edit: Doh, second image didn't show up.
Pretty sure this is what you are looking for....
IMAGE: https://lh6.googleusercontent.com/-vt_hw4DZRV4/U6zR1I9RUiI/AAAAAAAAG0I/dRWymEA2faU/s800/untitled-2014-06-27-.jpg
or I guess there is a small chance you just might prefer this....
IMAGE: http://danmarchant.com/wp-content/uploads/untitled-2014-06-27-.jpg
It is a little rough as it was done on a small JPEG and I only did a quick and dirty job. Obviously would be much better done on the RAW.
Straightened the horizon
Increased vibrancy
Used Lightroom's adjustment brush to select the subjects and increase exposure, reduce clarity, increase saturation and sharpness.
The above made the reds too saturated so I used HSL tools to target the reds and reduce saturation and the same tool to boost the saturation in the blues.
Dan Marchant
tonylong
...winded
Gallery: 60 photos
Jun 27, 2014 00:32 |  #5
Acevesf, what Raw processing software are you using?
Something I advise for folks new to shooting/processing Raw is that you use the Canon Raw processing software Digital Photo Professional (DPP) as a quick and cool "reference", because DPP uses the in-camera settings used to create a jpeg (or the embedded jpeg used in the LCD review) when rendering the preview of your Raw file. This means that your camera settings for Picture Style, White Balance and whatever other settings you have in use will show up in your Raw preview. So when you open an image, go to the Edit window and examine the settings in the Raw tab. You can see the Picture Style setting, examine the Raw and Contrast settings, and also look at the possibility that you are using the Auto Lighting Optimizer (the ALO/Lens Tab.
When working with Raw files in DPP you are free to change all those settings, and you can also Convert and Save (or Batch Process) to create a jpeg or tiff output.
But if you are happy with your current Raw processor, then after examining the settings in DPP, open the image in your "normal" Raw processor, looking to "imitate" the DPP settings and then to improve the image creatively! Close and don't Save the image in DPP to keep your file size down, since you can't "share" DPP processing with other Raw converters.
And then, it's possible that your camera LCD is set to be too bright, so that the actual jpegs are darker than they appeared! Learn to expose using the Histogram with the image Playback, rather than depending on the preview to judge things!
Tony
bionicle
Jun 27, 2014 03:29 |  #6
Heres my take on your photo.
edited in Lightroom and colour Efex pro 4
IMAGE: http://i559.photobucket.com/albums/ss36/Bionicle69/wedding-1_zps3cc76549.jpg
IMAGE LINK: http://s559.photobucke​t.com …ng-1_zps3cc76549.jpg.html  (external link)
5Dii gripped, 7D gripped, 70-200mm f2.8L IS II, 24-70mm f2.8L, 24-105mm f4L, 17-40mm f4L, 100mm f2.8L Macro, Sigma 35mm f1.4, Sigma 50mm f1.4, Canon Speedlite 580EX MkII x2
memoriesoftomorrow
Joined Nov 2010
Jun 27, 2014 04:12 |  #7
This?
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/06/4/LQ_688638.jpg
Image hosted by forum (688638) © memoriesoftomorrow [SHARE LINK]
Peter
tonylong
...winded
Gallery: 60 photos
Jun 27, 2014 13:52 |  #8
I downloaded your Raw file and opened it in DPP and noted that you have the Auto Lighting Optimizer (ALO) turned on, which does make a difference. With it turned Off it looks pretty much like it does in Lightroom (or Adobe Camera Raw) and like the shot you have posted.
As I suggested above, use DPP to open it and compare it.
Tony
mclaren777
Joined May 2012
Jun 29, 2014 02:58 |  #9
I've rarely come across a more challenging file.
Having them stand in the shade was a good plan, but you should have exposed for their faces, not the ocean. ;)
HTTP response: NOT FOUND | MIME changed to 'image%2fjpeg'
A simple comparison of sensor technology: Nikon vs. Canon (external link)
A technical comparison of sensor technology: Exposure Latitude (external link)
Thorrulz
Gallery: 20 photos
Jun 29, 2014 09:19 |  #10
Here is my quick and dirty edit.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/06/5/LQ_688801.jpg
Image hosted by forum (688801) © Thorrulz [SHARE LINK]
D800 I Nikon 200 f2 VR 1 I Nikon 200 f2 ED AI-S I Nikon 135 f2 DC I Nikon 28-70 f/2.8 I Nikon 50 f/1.4G I Nikon 85 f/1.8G I Pentax 645D I SMC FA 645 75 F2.8 I SMC FA 645 45-85 F4.5 I SMC FA 645 200 F4
My sister, the professional baker and cake decorator once told me that my camera takes great pics. My reply was that I thought her oven baked great cakes.:lol:
memoriesoftomorrow
Joined Nov 2010
Jun 29, 2014 10:28 |  #11
mclaren777 wrote in post #17000689 (external link)
Agreed. I can't help but think there was some sort of filter on the lens. The image was just so flat.
Peter
D ­ Thompson
Jun 29, 2014 11:25 as a reply to  @ memoriesoftomorrow's post |  #12
My take. Edited in ACR, then a Curves Adjustment and sharpening in CS6.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/06/5/LQ_688818.jpg
Image hosted by forum (688818) © D Thompson [SHARE LINK]
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
boerewors
Joined Sep 2009
Jun 30, 2014 22:27 |  #13
what is that flare like softness on the left side of the image? if its showing on several images i would be very concerned. looks like a lens issue? do you get this when using the same lens only or several lenses?
i downloaded the raw file and really had to push the exposure hard to get it to where it had to be. you should disregard what the screen shows you on the back of the camera. it always had me underexposing as well. to solve that issue i put the camera on monochrome and exclusively watch the histogram and totally ignore the percieved brightness of the screen. you can worry about colors later when you edit. well thats the way i do it anyway.
The most important piece of gear you own, resides in your head and its called your brain.
Eyeball2
Joined Jun 2014
Jul 01, 2014 07:06 |  #14
I would be willing to bet that the image softness, including the extra-soft left side of the image, is either from surf spray or from condensation on the lens elements. Both things happen frequently in tropical places like Cancun. The condensation, in particular, can be a real pain when you take your camera from an air-conditioned hotel room to the warm and extremely humid outdoors. Keeping the camera in a plastic bag with lots of silica gel packs can help or perhaps keeping the camera bag on the patio if it's secure enough. Otherwise it can take quite a while for the temperature to adjust and the condensation to evaporate. The condensation/humidity can also set off the humidity detector on some cameras.
drumsfield
Jul 01, 2014 09:39 |  #15
Next time use fill flash. It will do things PP will never do.
Canon 5D MkIII | Olympus OM-D | Olympus E-P2 | 16-35L MKII | 24-70L MKII | 70-200L MKII | 85L MKII | EF 50mm 1.4 | EF 100mm 2.8 | 100-400mm L MKII | 20mm 1.7
Feedback and Full gear list
Website (external link)
8,285 views & 0 likes for this thread, 24 members have posted to it.
Latest registered member is EBiffany
1317 guests, 109 members online
